Pin or not Pin
I would personally recommend just having the lines pinned that you can easily access and leaving the others for engine out work. It will drastically reduce your chance of getting stuck somewhere.
Also, my car has never been tracked, but it's done a couple 1/4 and 1/2 mile drag events.
My last car had over 50 track hours when I sold it. One pipe seeped at some point and was re-sealed. Otherwise, it never had an issue. I'd pin them when the engine is out. But otherwise, don't let it scare you.
I didn't let mine scare me and it popped in Battle Creek, MI. If I would have just taken some time to pin the fittings that are easy to access without dropping the engine I wouldn't have had to arrange for a 3 hour tow home.
I posted this in the tech forum but got no response. My 2004 996Turbo has 19k miles. After hearing about lines bursting I am thinking about pinning them. Is this a little like the IMS failure stories that scare guys to death? I know of a guy on another forum with over 160k miles and he hasn't pinned the lines. Is it necessary to do on a low mileage car?
Now go ahead.....think of some mods that will make you do an engine out and then while your in there go ahead the pin them. You;ll never have to worry about it again...
Not a super detailed DIY, but it gives you the basic idea of how to get to the fittings and what to use.
I had two different pipes let go, both on track. If you are going to remove the engine I would definitely weld them as opposed to pinning. My thinking is that pinning can prevent a major dumping but can't prevent the glue seals from letting go in the future and causing another leak and may require removing engine again! Welding on the other hand......end of problem. You do need to be selective on who does the welding. Requires a true expert.
I had Goldcrest do mine and overall it wasn't terrible.
Lost mine on my first ever track day (in a car) on the 2nd lap - so not that fast. Trailered it to GC in Atlanta and bought a $3k shirt that included an engine out coolant system refurbish with all fittings welded.
awdbiturbo1
Apr 8, 2010 10:39 AM
