Window Issue
Old Jun 21, 2020 | 01:57 AM
Bozbomber's Avatar
Bozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to all
Window Issue
My passenger side window seem to be off when fully closed, the rear section of the window touches with the rear passenger window. When I roll the passenger window all the way down, I could hear a light noise. Refer to attached photos taken from both driver side and passenger side window for reference.
Does anyone know what could be the problem and how to fix it? Thanks!
Old Jun 21, 2020 | 06:42 AM
sweeney186's Avatar
sweeney186 is infamous around these parts
Sounds like you need a regulator, very common on our cars. If it is not the regulator , you can adjust the glass fore and aft.
Old Jun 21, 2020 | 10:45 AM
Bozbomber's Avatar
Thank you Sweeney186, I was wondering if is the regulator but like to get some opinions.
Old Jun 21, 2020 | 10:24 PM
drinaldis's Avatar
drinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of light
Funny, I took this exact picture. I just pulled the door panel and adjusted the window forward about 5mm. Loosen the two clamp that pinch the glass, slide it forward and tighten.
Old Jun 21, 2020 | 11:22 PM
Bozbomber's Avatar
Nice to know, did you adjust it with the window rolled up or down?
Thanks!
Old Jun 22, 2020 | 08:31 AM
s65e90's Avatar
s65e90 is infamous around these parts
Take the door panel off and adjust the window.
Old Jun 22, 2020 | 09:07 AM
Bozbomber's Avatar
Thank you!
Old Jun 22, 2020 | 09:17 AM
drinaldis's Avatar
Thanks!
It was rolled down. I think that's the only way you can get to the fasteners. Be sure you mark where it is now with tape or something (down by the clamps). You'll want to move relative to those marks. Also, disconnect your battery cuz you'll have to remove the door airbag!!
Old Jun 22, 2020 | 11:27 AM
Bozbomber's Avatar
Cool! I really appreciated for all the tips!
Old Jun 24, 2020 | 11:50 AM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
If it's making weird noise too, it's probably on it's way out anyway. I replaced my regulator last summer because my window wouldn't drop down properly when I opened the door and then it would get stuck on the outside of the upper trim when I closed the door. It also was making fun noises when it went up and down. A new regulator fixed everything! If you do end up replacing it, remember to remove the extra set of stops on the bottom (I think they are for Boxter installs) so the window can roll all the way down. I forgot to remove them and had to go back in later.
Old Jun 24, 2020 | 04:05 PM
Bozbomber's Avatar
Thanks Vogz, my passenger side window does not make noise and I am taking the car to my buddy's shop to take the door card out see if I can just simply adjusted it.
Old Jun 24, 2020 | 07:30 PM
vogz's Avatar
Good stuff. Hopefully it's a quick and easy fix.
Old Jul 29, 2020 | 03:06 PM
Bozbomber's Avatar
I forgot to update, I was able to get the passenger side window adjusted without have to replace the window actuator!
Old Jul 30, 2020 | 08:43 AM
vogz's Avatar
Good to hear!
Old Jun 8, 2025 | 06:00 AM
manuel2171s's Avatar
manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s
https://www.sigmaaldrich.com/ES/es/p...BoCBIcQAvD_BwE
if its the one krytox, i prefer changing the gasket....it must be seriously good
it seems its misaligned, nobody try to forced the windows/doors?
cl6809
Sep 20, 2019 03:11 PM
nottoshabi
Oct 2, 2016 11:53 PM
Steve Jarvis
Dec 20, 2012 06:22 PM
