Question: Brake Service Kit
Old Aug 10, 2020 | 03:21 PM
Bozbomber's Avatar
Bozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to allBozbomber is a name known to all
Red face Question: Brake Service Kit
I acquired my 996 with a Markski 850hp turbo kit and for some unknown reasons the previous owner was running the car with the stock brakes and suspension. Took the car out for a drive to test out the new Tarrett front & rear sway bar drop links (came with a broken OEM rear drop links) and now looks like my brakes are due next.
I found this two Brake Kit (rotor/pad combination) offered by fcpeuro.com and ecstuning.com and wonder have any owners tried this band what are your feedback? Do they perform better than the OEM ones?
FCPEuro offers Zimmermann Rotor w/Textar Pads while ECSTunning offers Sebro Rotors w/Textar Pads
https://www.fcpeuro.com/products/porsche-brake-kit-zimmermann-textar-996brkt1
https://www.fcpeuro.com/products/porsche-brake-kit-zimmermann-textar-996brkt4
https://www.ecstuning.com/b-assembled-by-ecs-parts/front-rear-brake-service-kit/99635140904oekt3/
Thanks in advance.
Old Aug 10, 2020 | 04:37 PM
pancing's Avatar
pancing has a spectacular aura aboutpancing has a spectacular aura aboutpancing has a spectacular aura about
Thanks in advance.
They all perform like oem. Make sure you get new set screws for the rotors, if you dont have an impact screw driver (not to be confused with impact driver) and a deadblow you might strip the ones installed. I got the ecs set and it works fine.
On another note since youre due for new brakes you can use the 350mm 997tt rotors up front with a spacer kit, also use 997 pads.
Old Aug 10, 2020 | 06:10 PM
Bozbomber's Avatar
Thanks for the comments! Where can I source for a 997TT front bake with spacer kit?
Old Aug 10, 2020 | 09:45 PM
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
here is one source. You can and should do the rears too. https://racingbrake.com/rb-caliper-spacers-for-porsche-996-997-rear-upgrading-to-350mm-rotor-from-330mm-w-130mm-spread-qty-2-ea/]https://racingbrake.com/rb-caliper-spacers-for-porsche-996-997-rear-upgrading-to-350mm-rotor-from-330mm-w-130mm-spread-qty-2-ea/
In terms of rotors, just order 997tt parts
Old Aug 10, 2020 | 10:36 PM
Bozbomber's Avatar
Thanks Jayzbird!
Old Aug 11, 2020 | 11:23 AM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
freddy lewis sells a kit as well. I prefer to give the business to the other guys on the forum... i think his name on here is flewis763
Old Aug 11, 2020 | 04:55 PM
jayzbird's Avatar
I should also make my usual pitch (no association, just trying to spare others the stressful hassle of drilling out and time-serting stripped threads on the carrier) to swap out to Tarett caliper studs if you believe you will have occasion to remove calipers more than a couple of times over the life of the car. I’d say they are mandatory if you track often.
Old Aug 11, 2020 | 04:56 PM
jdexter's Avatar
Totally agree. I swap pads for the track, studs are basically mandatory.
Old Aug 12, 2020 | 07:44 AM
'02996ttx50's Avatar
if you're going with "oem replacement" then the "ATE" rotors are very inexpensive and will do the trick. i get all my stuff from pelican.
textar pads ( tend to ) squeal and suck. though they work and also are considered "oem replacement".
add: after reading the link it appears that the pad mfg'r in that set has addressed the issue of textar squeal not requiring counterweights.
caveat emptor. GL
Old Aug 12, 2020 | 01:57 PM
Bozbomber's Avatar
Thanks guys for the all comments!
Chris P
Oct 9, 2018 08:00 PM
FLA996TT
Sep 4, 2013 06:05 AM
cannga
Sep 29, 2011 07:35 PM
Tiago
Jan 27, 2010 02:44 PM
BlackBear
Mar 19, 2007 12:29 PM
