What actuators for a stage 2 map
Old Nov 6, 2020 | 04:10 PM
paulmorris's Avatar
paulmorris is infamous around these parts
I’ve a 996 turbo x50 running a stage 2 map, with de cats larger bore manifold and race exhaust.
ive not long purchased her and I thought it was running .8 bar of boost (seems low)
one of the actuators arms has just snapped, and now running just 0.4 safe mode.
I’d like to upgrade, so what would be a good replacement over the stock items, and what sort of boost should I be making ?
thanks in advance for your input
Old Nov 7, 2020 | 08:35 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
You need to talk to your tuner if you want to change the wastegate settings. The tune needs to be set up for it. You can go to 1 bar wastegates and I believe run upwards of 1.1 bar on those turbos.
Old Nov 7, 2020 | 02:05 PM
paulmorris's Avatar
I was sure it was only making 0.8 before the wastegate failed, does this seem a little low for a stage 2 map?
Old Nov 7, 2020 | 02:27 PM
brnrdtns's Avatar
On an X50 it does. Test for boost leaks and codes in your ECU.
Old Nov 8, 2020 | 04:55 AM
paulmorris's Avatar
New waste gates and Dv on order. Fingers crossed
Old Nov 25, 2020 | 02:40 PM
oem wgs only you can blow it up with after market... unless its tuned
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
shifter_
Aug 16, 2015 06:10 PM
willcoxmd
May 5, 2006 12:57 AM
AzExoticLover
Apr 25, 2006 06:46 PM
Mz3bo
Jul 19, 2005 11:30 PM
jamie
Dec 19, 2003 11:45 AM
