Engine to body ground strap replacement
Old Nov 23, 2020 | 04:21 PM
laalves911's Avatar
laalves911 is infamous around these parts
I have had electrical gremlins over the years, and have chased them in several different ways and frequently, things improved but then, occasionally they come back. The two specific gremlins are ABS/PSM lights coming on at warm idle and windows lowering on its own, car unlocking and interior lights turning on.
I won't bother going through everything I have done chasing these things but the fact is that I just measured the voltage drop from alternator to body ground and I got 0.471V which is excessive. Also, cold start, I only have around 13.5V at the battery and it creeps downwards. I also have an alternator regulator coming for good measure since the battery is also dead/dying and the voltage at the battery, engine running fluctuates. That's cheap and easy to replace.
Now, has anybody replaced their engine-to-body ground strap? If I remove the vacuum pump, oil filler neck and right intercooler hose, would I be able to get access to the strap's top nut to replace the thing or does this require an engine drop?
Old Nov 24, 2020 | 10:40 PM
BNasty's Avatar
BNasty is infamous around these parts
why not just add another temporary strap on another chassis point and see if it first fixes the issue.
Id also just check the connection points and tighten/clean them where they meet the chassis.
NormalFellow
Nov 19, 2024 06:43 AM
jtec963
Bentley
80
Feb 8, 2022 04:28 PM
ciaka
Jul 9, 2021 12:47 AM
lliejk
Dec 19, 2020 03:53 PM
harihoudini
Bentley
Nov 9, 2019 05:18 AM
