Blow off/diverter valve questions 996tt
Subscribe
Mar 17, 2006 | 03:14 PM
Since no one is responding in the tunning threads maybe this will help. (hope this is ok)
https://www.6speedonline.com/forums/...ad.php?t=44619
Reply
Mar 17, 2006 | 03:27 PM
Quote: Since no one is responding in the tunning threads maybe this will help. (hope this is ok)
Well, there is a difference between the two:
A "diverter valve" vents back into the intake, so you won't hear the "woosh" that you typically hear with an "open atmosphere" blow-off valve. They are the same thing, essentialy; one just vents into (diverts) into the intake while the other vents into (blows off) the atmosphere.
B. Because we run a MAF setup, the air volume is metered as it enters into the system behind the intake. The problem with running a blow-off valve is that some of the metered air is lost. The ECU, however, does not know this. You would have to program for this loss else you will run rich during shifts (when the throttle bottle closes and the BOV does its thing). Fuel is applied based on what the ECU "thinks" should be in the system. The amount of air that it thinks is there is not there, so it still adds the fuel causing a rich condition.
With that said, Sharky (Alex) has a BOV on his car that is drilled into the y-pipe. I believe that it is an HKS, but it might be a Blitz. You will want to ask him about his setup. Personally, I would stay with a diverter valve type setup...
Reply
Mar 17, 2006 | 04:02 PM
Wowsers!! I didnt think it would be that complicated. The thing is that Ive had a couple turbo cars in the past and I miss the BOV sound I appreciate your response and information thank you. I guess I ll let the famous sharky take it from here
(sound clips would be greatly appreciated) thnks in advance
-Sam
Reply
Mar 17, 2006 | 07:19 PM
Ruiner nice explaination sent ya some kudos!!
Reply
Mar 17, 2006 | 07:22 PM
Ruiner is THE man. Oh and he has a black 996TT of course
Oh and just to re-iterate. I did play around with that set up and I ended up getting it to work from car to car but only with an adjustable GFB unit. I too would stick with a DV instead of a VTA...
Reply
Mar 17, 2006 | 09:16 PM
my car has an HKS bov routed back into the intake. Sharky doesn't like it but it works for me
supposedly, the previous owner vented it to the atmosphere w/o any trouble; but what Ruiner explains is definitely true in most cases. to expand a touch, when the ECU dumps in the extra fuel, your car is likely to stall in near-idle situations (coming to a stop, etc.)
i'll probably try this soon - the car would love another noise
- chuck
Reply
Mar 17, 2006 | 09:22 PM
Quote: my car has an HKS bov routed back into the intake. Sharky doesn't like it but it works for me
- chuck
LOL I do actually like it- had it on my EVO but if you want I'll dig out my GFB adjustable one and it seemed to work way better. I have to say yours actually settled down more now with the new program Todd gave you. Idle isn't as rough for some reason
Mine wasn't too loud with the stock intake. Once I cut open the box and/or put the EVO conical style intake in I obviously got more sound...
Reply
Mar 17, 2006 | 11:12 PM
Quote: Ruiner nice explaination sent ya some kudos!!
Thanks! It comes from hard lessons learned in my previous years of modifying Japanese turbo cars...
Reply
- chuck
You are 100% correct on that point.
Reply
Mar 18, 2006 | 10:23 AM
Thnks to all you guys for the help. Anyone have sound clips or now where I can get em
Thanks again
Sam
Reply
Subscribe
