turn signal problems
Have you tested it with non led bulbs as in the original style? Have you checked the flasher relay ? A quick search yielded this……. I would start with testing the bulb, then the flasher relay, then you can get down the path of checking grounds and such. Hopefully a simple fix. -scrh1
https://www.6speedonline.com/forums/...-02-996-a.html
yep when switching to leds just get the relay that does not care about the load. no need for the resistors. did this on the 911 and a motorcycle. works great. just know that you will have no bulb out warnings now.
