FVD LED DRL not working properly
Old May 9, 2012 | 02:27 AM
Nydnarb911's Avatar
Nydnarb911 is infamous around these parts
FVD LED DRL (solved)
I got my LED DRLs in today that I ordered from FVD! Transaction went smoothly and was shipped on time, which I was very excited for, but after installing them I have run into a few problems. After installing the lights, I turned the car on and turned the light switch to the full on position. Only the LED strips came on on both sides. I'm not sure if that is what it's supposed to do or not, but I had the impression that all lights would be running at this point. I put the light switch in 'home' position and all lights turn off. I start the engine, turn the switch to full on position, only the LED strips are on. I turn the switch to home position, only LED strips are on. I turn off the engine, turn the switch from full on to 'home' and finally the LED lights and strip are both on.. but only on one side. The other side, only the LED strip is on. I'm not quite sure if I made an error during the installation, but this DIY was pretty easy and straight forward. Any advice would be amazing! Thanks in advance.
Old May 9, 2012 | 10:47 AM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
I have the ROTtec setup but with mine the LED strip comes on when the lights are on the second position or full light position. For the fogs to come on I pull the light switch in either of the 2 positions referenced.
Old May 9, 2012 | 12:26 PM
ELUSIVE's Avatar
ELUSIVE is infamous around these partsELUSIVE is infamous around these parts
Same
Old May 9, 2012 | 02:42 PM
GS997's Avatar
GS997 is infamous around these parts
Sorry to hear about your problem, and that I can't offer any advice because I'm brand new to the Porsche family myself, but I'd love to see some pics of what you did. So if you have some time, throw a few up here.
Old May 9, 2012 | 04:20 PM
Nydnarb911's Avatar
Sure, here are some pictures taken from my phone. My current situation is the LED strips are working properly when light switch is completely on and at the 'home' position. Fogs don't come on until after i stop the engine and switch back to 'home position'.
Old May 9, 2012 | 06:19 PM
GS997's Avatar
Wow thats looks incredible!! Good job. Now you just gotta get the kinks worked out, but as far as looks go its mint. If you don't mind my asking, what did that run you?
Old May 9, 2012 | 06:45 PM
paddyh's Avatar
paddyh is infamous around these parts
Bottom LEDs are supposed to only come on when you pull out the light switch into the foglight position or when the HOME function lights up the foglights so you can get into the house (HOME!). Everything you have described so far is 'as I would expect'.
* The LED strips replace the 'city light' or 'parking light' - these come on when you turn the light switch past HOME to either of the ON positions, or when you have the car turned off, and use the indicator or signal lever to up or down (left or right) and want to leave the city and tail light of ONE side of the car on to mark the presence of your car in a dark street
* The LED lights replace the fog lights (so you have to turn on the fog lights on the switch inside the car - these same lights are what lights up in the HOME position to provide the light you use to see while you are getting from the car to your home in the dark).
* The top LED lights replace the flashing direction indicator and flash orange and come on when you signal direction changes.
Were you expecting more? If you think you were getting some updated DRL capability where the bottom LEDs provide DRL function (which normally comes from the headlights on the 997.1) - then you need to add another module fully described in other threads on this forum.
You mention though only ONE LED light on in one scenario - I suggest you turn on the lights and pull out the FOGLIGHT switch, and check both sides fog light LEDs light up. If not, then re-seat the connector on that side, or I recall on one installation having to flip around the connector that replaces the light bulb from the original set (can't recall if that was the fog light or the city light).
Old May 9, 2012 | 10:15 PM
Nydnarb911's Avatar
Thanks Paddyh! +1 Your explanation helped thoroughly.
These ran me 509$ total after shipping (shipped from Florida to California) from www.fvd.us.
Old Nov 9, 2012 | 03:01 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
I posted a lot of detailed information into another thread here in case you also wanted automatic DRL functionality via the extra current sensing DRL module, but want to use the center horizontal white area as the DRL instead of the bottom, brighter LED portion.
Here's the link and my post is on Page 2: https://www.6speedonline.com/forums/...ml#post3687514
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
