All Electronics just shut off when trying to start
Old May 6, 2022 | 04:16 PM
Hijack's Avatar
Hijack is infamous around these parts
So I left my lights on and killed my battery. Now I couldn't jump it so I took it out of the car and put it on a charger for 24 hours. I just put it back in the car and upon connecting it, all the electronics came on. Yay! BUT, I went to turn it over and POW, all electronics went out. Now this sounds like a fuse to me, but not sure.
So first, what would be main fuse be that would shut EVERYTHING off? Secondly, why the hell would this happen? I mean I guess the battery could just be bad (its 4 years old), but would that cause a fuse to blow? Or is this something else all together. I'm about to go start pulling fuses and looking, but I guess that wouldn't fix the initial problem even if I found a blown one.
Thanks in advance for any insight!!!!!
Old May 8, 2022 | 12:02 AM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Buy a new battery.
Old May 12, 2022 | 10:38 AM
Scrh1's Avatar
Scrh1 is infamous around these parts
I’d replace the battery as a start. If no joy there then start chasing fuses and grounds and the ignition switch. If you have a durametric cable I’d see what it has to say as well on the readout. - scrh1
Old May 12, 2022 | 12:23 PM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Your ignition switch may have failed as well. Check threads in this and the Turbo 997 section on replacing the ignition switch.
Old May 15, 2022 | 10:20 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Def get yourself a new battery. Lead acid batteries don't like being fully discharged and will experience damage as a result. Not worth debugging anything else when batteries are so cheap.
You may want to check the grounds. Specifically the short ground cable that comes off the battery that is tied to the unibody. Check that the bolt is tight.
Old May 23, 2022 | 07:20 AM
s65e90's Avatar
s65e90 is infamous around these parts
The battery is dead.
Enclavet
Aug 1, 2018 09:34 PM
Dan997t
Apr 9, 2018 01:46 PM
Gusto88
Sep 19, 2014 08:29 PM
RCH
Feb 25, 2008 10:11 PM
