Why not bigger than 315s?
Old Mar 24, 2006 | 09:47 AM
ebaker's Avatar
ebaker is infamous around these parts
The increased OD would make my speedometer read MORE accurately.
Old Mar 24, 2006 | 11:32 AM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Originally Posted by MARKSKI
the offsets are 34 mm in rear and 41 in front. 4.5 inch lip.
cargraphic racing 3 piece wheel.
Are those offsets for 18 inch or 19 inch rims? What rim & tire size are you running in the front?
Old Mar 24, 2006 | 11:38 AM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
What is RuF running on the RT12? I think they are using 19"s with like 265's in the front and 355's in the rear. Then again, they are probably tubbing out the front and rear wheel wells to run that big...................
Old Mar 24, 2006 | 11:32 PM
ebaker's Avatar
MARSKI, were the 335's you tried rubbing on the inside?
I have 315's on stock ET45 11" rims. They are very close to rubbing on the inside rear wheel well liner over the turbo hose connector. The tire section width is 12.5". 335/30-18's on a 12" rim have a 13.3 - 13.5" section width. Almost all the extra width of 335's will have to go to the outside. I think it would take a wheel with an offset of ET25 to ET20 . This extra 1-1.5" of extra outboard tire width might rub too much on the fender lip, even if you roll it. A GT2 ET40 wheel with a 15mm spacer might fit.
Seems like Sharky was running 335's, but was rubbing holes in his fender liners.
Old Mar 24, 2006 | 11:37 PM
Life Dies's Avatar
Life Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud of
Why? It is so silly to assume it's going to do anything for you. You're better of changing the suspension geometry in effort to gain performance than silly tires.
Old Mar 25, 2006 | 01:33 PM
ebaker's Avatar
These cars have LOTS of weight on the rear tires. IMO the rear tire size is a limiting factor.
Old Mar 25, 2006 | 08:26 PM
Vicious's Avatar
Vicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond repute
The only 25 series I have seen to date is a 355/25/19 Might be worth looking into.
COBB Tuning
Jan 5, 2016 07:06 AM
Emre@Esmotor
Oct 19, 2015 12:06 PM
freddiemac
Oct 7, 2015 11:05 AM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
Texas1
Sep 20, 2015 09:12 AM
