removing gas pedal assembly
Old Apr 10, 2006 | 07:14 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
removing gas pedal assembly-updated with pedals pics.
I was wondering if someone can tell me how to take the gas pedal assembly out. I bought new pedals and the machined screws to install the gas pedal are about 1/8 inch too short to screw into the nuts. I was thinking I could drill some of the plastic material out from the back of the actual gas pedal to get the screws to catch the nuts.
Thanks for any help
Old Apr 11, 2006 | 10:02 AM
Bill Oxley's Avatar
Bill Oxley is infamous around these parts
I had the same issue with my new alum pedals. Easier to get slightly longer screws from the hardware store.
Old Apr 11, 2006 | 10:04 AM
wross996TT's Avatar
Use self tapping screws. They will hold just fine and the install is much easier.
Old Apr 11, 2006 | 10:31 AM
WOODTSTER's Avatar
Like Wross said, do not monkey around with taking pedal off,
I got self-tapping screws with my pedals from
www.ultimatepedals.com and it was 1.5 hour no-brainer.
get self tapping screws, no nuts needed on gas pedal.
MK
Old Apr 11, 2006 | 11:34 AM
M3CAB's Avatar
Thanks, I did end up going with the self tapping screws for the bottom 2 holes on the gas pedal. The top hole I used the machined screw and nut.
Old Apr 11, 2006 | 12:43 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
m3cab..post some pictures of everything completed...
Old Apr 11, 2006 | 12:52 PM
M3CAB's Avatar
will do once I get to my camera. Took me about 1 1/2 hours to do.....45 minutes of it just trying to figure out how to get the damn gas pedal cover on. The short machined screws screwed me up. I had to think outside of the box to get the gas pedal on...should have done that from the beginning. At least on my next car, I have learned what to do to make this easy. Live and learn.
Old Apr 11, 2006 | 12:58 PM
jamie's Avatar
What they said! I just installed mine last weekend. Don't screw around with removing the throttle.
I would definitely use at least one machine screw along with the tapping screws - you don't want that baby coming off!! Tapping screws are fine for the dead pedal.
Also, when you're screwing into the locking nuts, I found it easiest to use a small pair of vicegrips to hold the nut in place.
Old Apr 11, 2006 | 08:01 PM
M3CAB's Avatar
AirJordan23 here are some pics of my new pedals. Threw in some other shots of my car.
Old Apr 11, 2006 | 09:35 PM
wross996TT's Avatar
You should go with the black hardware...like mine.
NIKAS
Aug 20, 2019 07:53 PM
su_maverick
Sep 8, 2015 11:12 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
