Boost Gauge Suggestions.
Old Apr 27, 2006 | 10:39 PM
Zippy's Avatar
I want to put a boost gauge in my car. I would like it be on the steering wheel column if possible, so it's easy to see during pressing situations. Does anyone have a suggestion as to what meter to use? Digital? Analog? I want it to be relatively small and not too obvious.
Mike
Old Apr 27, 2006 | 11:04 PM
I only have the ones by the shifter.... I know that speed gallery makes a pod along side the left pillar...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 27, 2006 | 11:21 PM
Sideways's Avatar
Sideways has a spectacular aura aboutSideways has a spectacular aura about
I suggest you get one with a memory function. When the engine is running near redline and you are traveling fast there is no time to look at the boost gauge.
My choice was the Apexi gauge with peak memory and redlight warning. Not a cheap gauge at close to $300.
Old Apr 27, 2006 | 11:23 PM
Zippy's Avatar
Thanks Mark. That's a cool setup you have. I've also been contimplating a data logger and a boost controller like your. I may have to convert the awsome CD holder into an instrument area like you have done. It would be cool to have the boost gauge at "center ice" thought (hockey reference for you NHL fan's - Go Oilers!).
Old Apr 27, 2006 | 11:27 PM
yes I had the HKS one with memory as well... and I believe its a very functional tool especially when the BAR is so slow and inaccurate...
9.66
click to view
Old Apr 28, 2006 | 01:12 AM
acs-3's Avatar
acs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond repute
These are Defi gauges on my M3, they're black when turned off...
Old Apr 28, 2006 | 01:16 AM
defi is great but at $400 each... ouch...
9.66
click to view
Old Apr 28, 2006 | 01:22 AM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Are these boost gauge connect the same way as the boost controller?
Old Apr 28, 2006 | 01:43 AM
u just splice into a pressure source liek u do with a boost controller.. u use a T.
9.66
click to view
Old Apr 28, 2006 | 02:44 AM
Zippy's Avatar
Those are some pretty sweet gauges. Maybe I should stop screwing around and put in a stack on the "A" pillar.
Old Apr 28, 2006 | 11:44 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Someone post a picture of the A pillar application. Please!
Old Apr 28, 2006 | 02:32 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I also use a Defi-Link boost gauge.
Craig
Old Apr 28, 2006 | 08:32 PM
Zippy's Avatar
Craig
Where do you have your gauge (S?) mounted Craig?
Old Apr 28, 2006 | 10:04 PM
Craig's Avatar
Center console, along with my Smartire display, AEM a/f meter, and Sirius radio receiver (with a custom cover) (its a bit crowded -- doesn't look great).
Craig
Old Apr 28, 2006 | 10:10 PM
Zippy's Avatar
The center console seems like the easiest spot. I like your A/F meter. Good idea.
