Ice on Intercooler for Drag & Dyno?
Old May 5, 2006 | 08:22 PM
Turbo Fanatic's Avatar
So I'm brainstorming......
Anything wrong with the idea of dumping a bunch of ice into the into the intercooler ducts for drag strip and dyno?
Seems like it's a ready made container AND the water drips behind the rear tires!
Jaycla: I'm going to LAPD tomorrow at 3:00P. They have an AWD dyno, but it's not safe for the turbo. RWD it is.
Anyone want to take dibs on what a GIAC (91 octane) Program, Remus exhaust, Evo intake X50 will run in RWD?
Old May 5, 2006 | 08:52 PM
iLLM3's Avatar
Im also interested in tips for dynoing
Old May 5, 2006 | 08:58 PM
Porscheboy16's Avatar
Porscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of lightPorscheboy16 is a glorious beacon of light
About 520-530 at the crank?
Old May 5, 2006 | 09:27 PM
Ist not a good idea to use crank numbers since we all use different % figures.... I use 12.5%.. RWD.... and 17% for AWD.... I seen others use 22 % and as low as 15% for AWD... so let make it clear and use
RW numbers... and PEAK HP numbers to be exact... casue we are all looking for a peak to make us feel better that out car is XXX HP LOL.
I say 470 rw HP ??? Im guessing.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 5, 2006 | 11:48 PM
I'm more concrned about reading the A/F ratios. Never dynoed a car. It should be fun.
Old May 6, 2006 | 12:02 AM
trev0006's Avatar
trev0006 has a spectacular aura abouttrev0006 has a spectacular aura about
I agree with your numbers, 450-470rwp on 91 gas.
Old May 6, 2006 | 12:27 AM
That sounds kinda low. Isn't this package supposed to be good for 560 crank HP? I guess 560 x .85 = 476
Any opinions on icing the intercoolers?
Not that it matters really....
I'll try and post the graph tomorrow!
Old May 6, 2006 | 12:39 AM
trev0006's Avatar
I know a few that went to LAPD for dyno and got around the whp figures posted but they where 16/24 hybrids, as far as the ice if the fans are not pointed at the intercoolers then the ice might help but if they are pointed I think it would hurt power since the ice will block the fan air from going through the intercoolers.
Old May 6, 2006 | 04:41 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
I am sure the ice will help at the track, just keep in mind the track attendants take a dim view of any car leaking ANYTHING in the staging lanes. Good luck.
Old May 6, 2006 | 07:58 PM
redjeeper's Avatar
redjeeper is infamous around these parts
You have to use dry ice to prevent it from leaking, it will just evaporate.
MrJoshua
Sep 6, 2015 02:06 PM
