Mildew Smell- Please help
Old May 13, 2006 | 07:17 PM
Divi996tt's Avatar
Divi996tt is infamous around these parts
Hi Guys, I'm having a problem and dont know what is causing it. Everytime I turn on the AC, a smell of mildew comes up. It last for about 30 seconds and then goes away.. Do I have to drain something? Put bleach in any place ? Or change a filter?
Thanks for the Help,
Divi
Old May 13, 2006 | 07:19 PM
joekimdds's Avatar
joekimdds is infamous around these parts
change the filter...and check the freon level
Old May 13, 2006 | 07:59 PM
tom kerr's Avatar
I really think this happens in almost any car. If the car is turned off with the ac running the system doesnt get a chance to get rid of the condensation and then you get the mildew smell at start up.
I usually run the car and fan for a few minutes with the ac compressor off. this gives the system a chance to "dry" and then I dont think you will have the same problem.
If you do and even if you dont the filter change certainly cant hurt either!
Old May 13, 2006 | 08:38 PM
CamNeelyphile's Avatar
CamNeelyphile is just really niceCamNeelyphile is just really niceCamNeelyphile is just really niceCamNeelyphile is just really nice
This is a common problem with this model.
Old May 14, 2006 | 01:59 AM
RufMD's Avatar
RufMD is just really niceRufMD is just really niceRufMD is just really niceRufMD is just really nice
change your shorts more often...
JK
Old May 14, 2006 | 02:20 AM
20C4S's Avatar
condensation or mole in the AC system. change filter might help but i usually turn the heater on for couple minutes let the hot air run through the system. works for me.
Old May 14, 2006 | 05:11 AM
Divi996tt's Avatar
Ran the heater for few mins and the mildew smell is gone !!!!!!!!!!!!!!
Appreciate your help.
Cheers,
Divi
Old May 14, 2006 | 12:01 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
I would occasionally shoot some ozium through the exterior inlets to clean the system. It won't kill mildew but seems to cut down the smell quite a bit.
Old May 14, 2006 | 12:37 PM
20C4S's Avatar
Cheers,
Divi
glad it helped. the smell will come back from time to time but a quick fix would last for a while.
Old May 14, 2006 | 12:57 PM
tom kerr's Avatar
Ha!!! glad to hear it!!!
Divi996tt
Apr 22, 2010 03:28 PM
yemenmocha
Nov 12, 2009 03:51 PM
