AX22 Arrived Today
Originally Posted by powder
When timing such a run do people get a running start or cruise at 60 then go?
Begin around 40 MPH and go to about 150 MPH.
Then you analyze the data from 60 to 130
Originally Posted by Porscheboy16
Running start.
Got my AX-22:
problem...I do not have the slightest idea how to even power it up???
It does not come with (1) printed word on directions or set-up: Nothing ???
somebody who knows how this very, very well made device hooks up
in my car (first time from fresh packaging to getting me set-up).
please call me (I will not be using my pm for the rest of the weekend)
Marty K
612-247-2270
952-443-0100 (home)
thanks in advance.
Marty K
612-247-2270
952-443-0100 (home)
thanks in advance.
Marty, everything is on the supplied CD or their website. To power it up you simply plug adapter to your lighter socket and then plug the other side (the little orange multi-pin) to the back of the unit.
From the Help icon in the software:
Power Supply And Earthing
Powering the AX22/DL90/DL1/DL2
The AX22/DL90/DL1/DL2 units are supplied with a power lead for connection to a standard car cigarette lighter socket, with the centre pin connected to +12v and the outer of the connector connected to vehicle ground. If appropriate (typically on a road car), this can be simply attached to a cigar lighter type connector and the lead plugged into the unit to power it, however in many cases it may be more appropriate to either permanently power the device from the vehicle loom or power the system from a separate battery, details of how to do this are below.
The power plug used to power the DL90 and AX22 is a "2.5mm short connector".
Permanently wiring into the vehicle
If the DL90/DL1/AX22 is to be wired directly into the engine wiring loom, rather than using the cigarette lighter socket, a fused supply must be used, with a fuse rating of no more than 1 amp. It is also highly recommended that the unit has it's own external power switch so it can be easily turned off. We also recommend that the DL90/DL1/AX22 power supply is isolated from the power supply when the car is being cranked over and only turned on when the engine is running. It is possible that leaving the DL90/DL1/AX22 turned on during cranking may corrupt the data in the logger.
Also please note that in all cases the GPS receiver is powered on whenever there is power to the main unit - it does not turn on and off with the main unit, so if the DL1/DL90/AX22 is left connected to the battery it will flatten it.
Guest
Posts: n/a
. So no datalogging! Sorry guys...I will try again next week...On the other side of the coin...the Camaro ran back to back 9.90's at 138mph ON THE MOTOR (no NOS)Attachment 34354 !! I am very happy...the car was a carewalk to drive...The front end pulled of the ground about 12-18 inches on the launch and then straight as an arrow...The SB2 394CID motor loves to rev to 10K...I will set the NOS to a 275 shot and run the car with NOS in about a week...I will post the video next week for you guys to see...
Attachment 34355
This is a previous picture that Miller Racing took when they ran the car..
Unfortunately, I believe our ax22 will not be accurate in a car that leave the line real hard. After reading the instructions I noticed that ours have a maximum reading of 2g's. There is a 10g option though. A drag car or a really fast Porsche launched hard enough can max that out even though it's only for a second. It will still effect the accuracy of the unit in my opinion. Also it will not take into effect the roll out at the starting line which can vary. However in all other areas of performance it should be dead on. I hope I'm wrong about the 1/4 mile though.
Joe R
Joe R
Joe R
Joe R
Nice 3 page article about your car on Total 911 Magazine!
I don't know how the AX will react to this but I would guess that the GPS (per Ebaker) will still give you the right time vs. speed vs. distance measurements even if the accelerometers are fooled. It would be interesting to know what sort of Gs these cars pull from a stop on a drag strip.
Alex, it is the Porsche we would like to see, I am sure it has a lighter socket?
Joe R
Joe R
Has anyone seen 60 to 130 faster than 8 seconds?
Originally Posted by VRAlexander
But make CERTAIN THAT YOU LIGHTER SOCKET WORKS!!! We (Chris Chow, Birdman and myself) went to test and tune on friday to run the 95 Camaro (from PINKS). I was all excited to use the AX-22..Then when I pugged the unit into the lighter plug...pooof -short- no power...I replaced the fuse and poof again
Attachment 34355
Attachment 34355
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Oct 13, 2015 03:45 PM
