145 in 4th
Old May 30, 2006 | 12:03 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
145 in 4th
hit 145 in 4th with more room at the top was very surprised when i saw speedo.. felt like 100...what does this equite to in terms of top speed????????
Old May 30, 2006 | 12:09 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Steve,
A wrong speedo.
You should be hitting around 130mph or so in 4th. if you have a TT with stock redline and tire sizes...
Old May 30, 2006 | 04:35 PM
I agree with Jean. at the 1/4 track I trappped 126 mph with a few hundred rpms left. strange...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 30, 2006 | 04:41 PM
tom kerr's Avatar
this is the correct info from an expert on rennlist... something is wrong with you or the car IMHO unless you have changed factory gears, ring pinion or tire sizes
Yesterday, 07:21 PM #2 Dock vbmenu_register("postmenu_3099802", true);
Specialist
1st - 39
2nd - 73
3rd - 106
4th - 133
5th - 162
6th- 195
All at 6750 rpm except for 6th which is at 6600 rpm.
Old May 30, 2006 | 06:20 PM
iLLM3's Avatar
Well i have the raised limiter to 7k-7100 and just watched a speedo video from 40 mph in 2nd to top of 4th and it hit about 139-141mph by 7k flat, cant really see the number but looks to be about 140 maybe a little more!!
Old May 30, 2006 | 09:03 PM
Sideways's Avatar
Sideways has a spectacular aura aboutSideways has a spectacular aura about
Are you familiar with the turnzero gear calculator. They have a 996 setup. Just click the variables for a vehicle and pick the one you want.
If you change the final drive, tranny gears, tire size, etc you can plug in the changes and bingo.
www.turnzero.com/technical_resources.php?resource=gear_calculator
Old May 31, 2006 | 12:07 AM
Jean's Avatar
Tom
Those speeds are for the 996GT2, it has same gearing but taller tires, the TT reaches slightly lower speeds at same RPMs.
ILLM3
At 7-7.1K RPM you will see about 4mph more, 134mph or so.
Sideways, nice link! The gearing shown is for a 996 Carrera, in 4th gear the TT and GT2 have a ratio of 1.12 whereas the Carrera has a shorter 1.22. So it needs to be changed on the software as you said.
Old May 31, 2006 | 03:48 AM
iLLM3's Avatar
Originally Posted by Jean
Tom
ILLM3
Interesting, like i said i see about 139-140 in the video, i can host it if you would like to see, this was on ROW suspension, stock wheels and tires!
Old May 31, 2006 | 03:58 AM
Jean's Avatar
ILLM 3
It is normal to have that sort of speedo inaccuracy. It is actually little!
Old May 31, 2006 | 07:27 AM
WOODTSTER's Avatar
time to buy yourself an AZ-22 and see your real speeds.
MK
Old May 31, 2006 | 04:26 PM
tom kerr's Avatar
thanks Jean
Old Jun 1, 2006 | 11:17 AM
buddyg's Avatar
The tt speedo reads about 4-5 mph high.
Old Jun 1, 2006 | 11:34 AM
Ruf-Racer's Avatar
Ruf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura about
Speedo
Is nonlinear,always reads higher at the top. Jean knows as do others that have spent a lot of time going fast. A GPS with high gain antenna is easy to use for verification.
Cheers
R
Bobbyfali
Jul 31, 2017 01:28 AM
cherplex
Oct 1, 2015 08:30 PM
uurfantasy
Sep 23, 2015 09:10 AM
troyztoyz609
Sep 17, 2015 06:09 AM
oo7
Sep 10, 2015 08:08 AM
