2WD 996 Turbo - True or Fiction ?
Old Jun 26, 2006 | 05:57 PM
  #106
iLLM3's Avatar
Originally Posted by SDboosted
another way to make it (much) more exciting is adding power.
600HP is a great place to start!
Still wouldnt change the feel of the car enough, to enjoy the other 50% of the car, that is handling! The car feels so on point in RWD mode, honestly, the people who havent done it have no idea!
Old Jun 26, 2006 | 06:59 PM
  #107
Turbo Fanatic's Avatar
This is obviously very subjective. I would say 600HP is a great place to stop, many have voted otherwise.
Old Jun 26, 2006 | 07:03 PM
  #108
Divexxtreme's Avatar
Old Jun 26, 2006 | 07:07 PM
  #109
I didn't mean 600 WHP divex
Old Jun 27, 2006 | 02:21 AM
  #110
iLLM3's Avatar
Old Jun 27, 2006 | 02:49 AM
  #111
trev0006's Avatar
trev0006 has a spectacular aura abouttrev0006 has a spectacular aura about
lets see what my shop will charge for this mod, I think I will try the shaft disconnect first before going all out removing the front diff. I have the stage 4 with race gas program and want to see if traction is an issue.
Old Jun 27, 2006 | 03:18 AM
  #112
iLLM3's Avatar
My car is definitely a STRONGGG stg2+, and i only have tracion issues 1st but then catches, occasionally in 2nd and really only when im coming out of a turn. I think you should be good, try it out you will enjoy it
Old Jun 27, 2006 | 04:44 AM
  #113
kiko's Avatar
kiko is infamous around these parts
Would anyone please do a resume of this mode? Like, parts involved and part numbers, etc? Fotos of the procedure would be the cherry on the top...
Does anyone knows the price of an LSD?
Old Jun 27, 2006 | 08:49 AM
  #114
Mz3bo's Avatar
Mz3bo is infamous around these parts
Kiko... feels like this is a national secret... getting a full description with steps and parts involved + pro and cons is harder than getting an interview with the Pope... I feel like it's a teasing game, they give a little info, but not more or enough to let all the 6speeders understand the whole process in full...
Old Jun 27, 2006 | 10:45 AM
  #115
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
The mystery has been revealed, please refer to my thread on my RWD conversion...https://www.6speedonline.com/forums/...ad.php?t=51662
Old Jun 27, 2006 | 11:02 AM
  #116
PorschePhd's Avatar
Wow, well the only thing we have done different was press out the bearing and use the standard C2 bearing. This is why the stub axels will not fit the other way.
Old Jun 27, 2006 | 11:48 AM
  #117
Ahh, that explains it. When they tried putting in the C2 stub axels and seeing that they didnt fit, their thought was just to take the 996tt stub axels off the CV joints and use them (saved me about $300 in parts). My car seems to be running fine using the 996tt stub axels and bearings as both the ABS and PSM are working properly.
Old Jun 27, 2006 | 12:59 PM
  #118
iLLM3's Avatar
Seeing martin used his 996tt stub axels, do you recommend using the C2 pressed out like you mentioned, or his way??
Old Jun 27, 2006 | 01:18 PM
  #119
I'm pretty sure that the C2 stub axel doesnt fit into the 996tt wheel hub. The 996tt stub axel is like 76mm and the C2 stub axel is 90mm even though it has the same number of teeth.
Old Jun 27, 2006 | 01:20 PM
  #120
iLLM3's Avatar
Well he explained how people do it by pressing it out or whatever. So what would be the advantage of people using the C2 stub axel over the stock 996tt's?!?
