2WD 996 Turbo - True or Fiction ?
I wonder how much faster the car is when in 2wd mode in a straight line, we need a 60-130
run on two stock or similar moded cars. I have heard you get 6% more power to the wheels in the 2wd mode.
Originally Posted by trev0006
I wonder how much faster the car is when in 2wd mode in a straight line, we heed a 60-130
The car is definitely faster in RWD mode. It is not any harder to drive though.
I will say the car has better grip in RWD with new PS2s than it it did in AWD mode with the old factory Pirellis. The pirellis were serioulsy spinning in 1st and 2nd in AWD mode.
Originally Posted by USCTrojanMan29
Well, I heard that taking out the diff and drive shaft you loss about 300lbs and every 100lbs is worth about 10-12hp to the wheel....
Originally Posted by rwm514
300lbs! that seems like alot. I thought I remember reading a while back that it was more like 150lbs.
I had speed gallery do it. Three bolts on one side and slide off the spline on the other.... voila!
BTW I've heard 150 LB too. The only diffrence between a GT2 and a TT is the rear seats, front drivetrain and PCCB (in terms of weight).
GT2 = 3175
TT= 3480
The difference is 305 pounds! maybe 200 lb for the drivetrain is not far fetched!
GT2 = 3175
TT= 3480
GT2 = 3175
TT= 3480
GT2 = 3175
TT= 3480
Originally Posted by Divexxtreme
It's more like 130-140 lbs. I weighed everything that was removed from my car on a calibrated scale.
GT2 = 3175
TT= 3480
GT2 = 3175
TT= 3480
Originally Posted by iLLM3
Yea but doesnt mean it will feel like a GT2. 996tt would have to be upgraded heavily suspension wise, then it might be a pretty close match! Hmm i want to do the RWD swap now..
Interesting Scott...what parts did you buy for the conversion? Just the C2 stub axels and GT2 cover plate? I'm hearing that the cover plate is optional.
Sorry guys, but what exactly is the "stub axel" ? Also, I saw on the part list that the GT2 has LSD, what will happen if you run the TT transmission without LSD , will it be more stress to the transmission ?
