2WD 996 Turbo - True or Fiction ?
Old Jun 22, 2006 | 07:55 PM
  #91
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Originally Posted by ari
Trojanman29: What shop is doing the work for you? I am anxioulsy awaiting your report. Keep us updated.
The shop's name that is doing the work is Carl's Place located in Las Vegas. They have been around for 30+ years and all they work on is Porsches, from the old ones to the newer ones. All of the mechanics are ex-porsche dealership guys and the owner is an abid porsche guy (does a lot of racing). I've been over there twice and have my own tech that's assigned to my car (guy who knows the ins and outs of a 996). I'm dropping the car off tomorrow morning and if all goes well I should have it back Friday afternoon.
Old Jun 22, 2006 | 08:32 PM
  #92
PorschePhd's Avatar
I'm positive that the GT2 and X50 and TurboS models have the same engine and am pretty sure they have the same tranny (different cover plates).
I will confirm that they are exactly the same. There is no difference other than the nose and tranny cooler. All else from the pump to the turbos is the same.
Old Jun 22, 2006 | 08:53 PM
  #93
Turbo Fanatic's Avatar
Originally Posted by iLLM3
Very true! Anyway Ari, how long did it take to just disconnect, you said 3 bolts, slide of spline and your done. Everything works after that (psm + abs?). I might have it done tomorrow to see how i like it!
Yes. just that and everything works.
Old Jun 22, 2006 | 08:54 PM
  #94
Thanks it's great getting professional confirmation.
Old Jun 22, 2006 | 10:00 PM
  #95
iLLM3's Avatar
Cool man, any diagram or picture of exactlyw hich bolts, my shop will know im just curious
Old Jun 22, 2006 | 10:02 PM
  #96
I haven't looked under the car, but have seen the driveshaft when I took it home.
My sense is that it will be painfully obvious. I also beleive there is a plastic cover or undercariage air management piece that must be removed to get to the driveshaft?
Old Jun 22, 2006 | 10:03 PM
  #97
Ryan in SD's Avatar
Ryan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to all
It was mentioned like 5x in the thread lol jk.. But its said to be around 150-200 lbs give or take! Your talking about for the front drivetrain and diff removal, not a complete stripdown to gt2 spec correct?
Thanks, thats what I wanted to know. Reading through 6 pages seemed daunting a the time and I wasnt sure if anyone would bring it up.
My assumption failed!!!!!!!!
  #98
iLLM3's Avatar
Hmm im going to try and find a pic, maybe someone else can chime in also!
Old Jun 23, 2006 | 03:24 AM
  #99
I'd be curious to see a picture of under the car too.
Old Jun 23, 2006 | 06:38 AM
  #100
Mz3bo's Avatar
Mz3bo is infamous around these parts
Sorry guys, but what exactly is the "stub axel" ? Also, I saw on the part list that the GT2 has LSD, what will happen if you run the TT transmission without LSD , will it be more stress to the transmission ?
Old Jun 23, 2006 | 08:35 AM
  #101
03-turbo911's Avatar
Senior Member
Won't stress the tranny, it'll just make the car a more handfull on aggressive driving. An LSD is a great idea if you want to stay two-wheel drive.
Old Jun 23, 2006 | 11:58 AM
  #102
Yeah, but how much does a rear LSD run?
Old Jun 23, 2006 | 05:51 PM
  #103
***update***
I just got back from the shop a little bit ago...here is where they are at. They took out the drive shaft and front diff. They also removed the front axels, cv joints, and 996tt sub axels. When they went in to install the C2 stub axels they noticed that it was a larger diameter unit as compared to the 996tt. So they went ahead and removed the 996tt stub axels from the cv joint/axels and will be putting them back in. They will road test to see if all is well and let me know by the end of the day. The total weight of the drive shaft, front diff, and front axels & cv joints is approx. 125lbs.
Stephen - Tony over at Carl's Place sent you an e-mail about a few questions...if you can respond to him by tomorrow morning I'd appreciate it!
Old Jun 23, 2006 | 07:29 PM
  #104
iLLM3's Avatar
Nice Martin.. Mine is being disconnected today, will pick it up tomorrow and see how it feels. Looking forward to your review
Old Jun 26, 2006 | 05:51 PM
  #105
SDboosted's Avatar
SDboosted is infamous around these parts
another way to make it (much) more exciting is adding power.
600HP is a great place to start!
