Need DIY instructions to fit an exhaust
Old Jun 8, 2006 | 02:41 PM
kiko's Avatar
kiko is infamous around these parts
What I said... Can anyone help me?
Thank you in advance.
Old Jun 8, 2006 | 02:48 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Found this on Imagine Auto website.
http://www.imagineauto.com/tips4.htm
Old Jun 8, 2006 | 03:03 PM
wross996TT's Avatar
Kiko, What exhaust? I have the Europipe instructions if you need them.
Old Jun 9, 2006 | 05:21 AM
definately take the bumper and ICs out... fold out the protective shield and get the correct tools so u dont strip the 2 sides bolts otherwise it may turn into a very expensive project.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 9, 2006 | 05:51 AM
kiko's Avatar
Thank you guys!
Wross, I got an Europipe but its for the gentleman who bought my GHL motorsport. Thanks.
Old Jun 9, 2006 | 08:09 AM
PorschePhd's Avatar
M3Cab has it on the nose.
Old Jun 9, 2006 | 08:16 AM
wross996TT's Avatar
Originally Posted by kiko
Thank you guys!
OK, I thought you had Pipes, that's why I replied...so no need to send the instructs. to you.
Old Jun 9, 2006 | 09:59 AM
kiko's Avatar
Thank you once again Stephen to the service provided to this great community!
Old Jun 9, 2006 | 12:06 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I have changed my exhaust 4 times and never removed the bumper or IC's
Old Jun 9, 2006 | 12:09 PM
AMG ETR's Avatar
Its not required just makes it easier... I personally just remove the bumper (not IC's) and have had no problem...
Evan
Old Jun 9, 2006 | 12:11 PM
for someone who never did it.... getting the nuts close to the outside may be difficult.. especially when they are corroded and baked on form heat. I also change mine out a few times... and had some issues with the two sided stud thats holding the cat and the the turbo... so I only suggested to do so in order to prevent someone from stripping the nut... then having to cut it off.. then still having a MAJOR problem taking the stud out of the turbo to replace it.
so someone who has never done it... u might as well spend an extar couple of hours to prevent this form turning into a knightmare... casue it can be.
It may go smoothly but in my case I had one nut that simply didnt want to go... more then once... from the heat.
its very important that u have correct tools to get in on the sides near the heat shields.
this can also be a good time to inspect the coil packs and maybe even change plugs... especially if its a 2001 TT
just a thought.
markski
9.66
click to view
Lucid Moment
Aug 20, 2015 02:22 PM
