intercoolers
Old Jun 24, 2006 | 05:19 PM
  #76
Yes Marty, Todd K has been doing custom ICs for a few years(himself).
Scott and alexander both have them. I did my own with the help of Todd(sizing and spec help). I ordered 3 sets of different sizes and we went to work. Todd approved my design and it looks like they will perform great.
The trick is also to use as much as available space for the end tanks... and yes there are better and worse designs. With that said, I believe that, as long as the evoms ICs are bar and plate- I believe they are getting them form the same source as I, then they are great for the price. Even $3K for the pair is fair. Trust me I know what goes into making these...
On another note, the evoms endtanks were colored black. what material are the end tanks... hope they are not plastic like the stock ones...
You guys get them and stop wining... its the best option for those living in hot climates to date. I would choose ICs over headers anytime... if I had to choose. And they are direct replacement... alot of R&D went into this.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 24, 2006 | 05:55 PM
  #77
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Doc are these bar and plate design? Also what material is the end tanks made of?
Old Jun 24, 2006 | 06:03 PM
  #78
Zippy's Avatar
The end taks are cast aluminum.
Old Jun 24, 2006 | 06:05 PM
  #79
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
EVOMS' intercoolers are bar and plate, and the end tanks are metal, not plastic (the one in the photo appears to be powder coated.
Craig
Old Jun 25, 2006 | 03:17 AM
  #80
oak's Avatar
oak
aluminum casted end tanks? are the hose attachments and the end tanks made from the same casting? seems if it's made from aluminum casting could have some leak or weak hose connections over time. strength for castings are not the same as forged 6061 or 7071.
Old Jun 25, 2006 | 05:48 AM
  #81
cjv's Avatar
cjv
Moderator
Originally Posted by rmrmd1956
Does anyone know the efficiency of the stock and GT2 intercoolers at .8bar,1.0bar,1.2bar,1.4bar? Thanks
I believe (if my memory serves me correctly) stock IC's are approx. 76% efficient and GT2's are 78% efficient.
Old Jun 25, 2006 | 10:01 AM
  #82
PorschePhd's Avatar
No Oak, reread the post. You do not reuse the hose connection. You use the high pressure band clamps. The ends are removed from the hose and the new intercoolers are built to have that end slip in. You will not be able to use a stock end with these intercoolers.
Old Jun 25, 2006 | 10:50 PM
  #83
oak's Avatar
oak
stephan, do you have a pic of what this hose attach looks like. hmmm.....is the hose attach just a slip on fit with clamps directly onto the cast ends?
Old Jun 25, 2006 | 11:39 PM
  #84
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Thanks Chad
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
ECS Tuning - VW
Sep 25, 2015 02:22 PM
