Side scoop removal
Old Jun 25, 2006 | 05:25 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Side scoop removal
I've seen the pdf graphic on this, but who here has personally removed the side scoops of their turbo, and can you give me a step by step please?
Thanks.
Old Jun 25, 2006 | 11:36 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
They just pop out.First start in the lower corner close to the door using a rubber wedge tool.Pry gently out away from body while moving upward to the top of the side vent.gently pull out and toward front of vehicle.It is held in with clips that snap in similar to the clips that hold the shifter boot in.Hope this helps.
Old Jun 26, 2006 | 05:51 PM
Thanks Joe!
Old Apr 8, 2012 | 02:05 PM
rennwerkes's Avatar
rennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to behold
I just removed my vents and wanted to add a bit of clarification to the procedure in the hopes it'll help folks in the future.
Using the plastic wedge tool you want to pop/pry the vent off the clips. The clips are lined at the 12 and 6 o'clock position of the vent and also the forward leading edge closest to the door. Once you start removing the vent you'll be able to see what I mean.
There are also two pressure type of clips on the rear edge of the vent assembly. These clips are just holding the vent snug to the body.
Once the vent is separated from the clips this is when you gently pull the vent forward and out of the vent cavity.
This is also a good time to replace the gasket connected to the vent. Mine was in pretty bad shape.
Clean up the vent (mine was pretty dirty), polish and reinstall.
Old Apr 8, 2012 | 02:19 PM
kato1453's Avatar
kato1453 has a spectacular aura aboutkato1453 has a spectacular aura about
I would love to see some pictures. You know worth a thousand words and all!
Old Apr 8, 2012 | 02:24 PM
rennwerkes's Avatar
Roger that!
I'm usually not one to take pics while I'm working on the car.
I put everything back together already.
The vents are plastic and I'd rather not keep removing and reinstalling.
However, I am going to purchase new gaskets so will take pics when I do the job again which should be in a week or two.
Will post then.
Old Apr 15, 2012 | 08:07 PM
rennwerkes's Avatar
Here you go.
I also noticed that the sides of the clips have a tendency to bend outwards when you pull the side scoop away from the car. Just bend them back so that all the clips look consistent. I also swapped the bottom clip with the top one. The bottom ones seem to rust a bit more than the others. I guess eventually I'll just buy new clips.
I also assumed that Porsche would sell the gaskets separately. Guess what? The only way for you to get them is to buy the whole intake assembly!
Old Apr 15, 2012 | 09:03 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
thake a plastic shoe horn to the lower left hand corner it will pop right out be sure it's plastic do a search i think i took pics and posted them
Old Apr 15, 2012 | 09:14 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Oct 14, 2015 07:00 PM
I'mAllIn
Sep 11, 2015 06:38 AM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
gulf gt
Aug 27, 2015 10:27 AM
