Dyno Results Whats Your Opinion???
Old Jul 12, 2006 | 01:41 AM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
91 Octaine program 1.1 1.2 boost
It was done on a dynapack the wheels where removed
and the dyno bolted to the wheels
your opinions please on the state of the tunning based on the dyno results
thank you
Boris
Old Jul 12, 2006 | 02:58 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Looks like it leans out above 5300 rpms. I think you need more fuel.
Craig
Old Jul 12, 2006 | 03:29 AM
I AGRREE as well. I had the same set up but I ran a 5 bar which helped alot...
but then hes running it on 91 octane and at 1.1/2 bars ... he probably should stay under 1 bar.
I ran 100 octane on the same set up and ran 11s afrs at 1.3 bars but anything after that I needed fuel.
Boris, is that ur stage 5 set up or is it something else.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 12, 2006 | 06:46 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
Boris
Wow, if your wheels could do that alone imagine what numbers you could generate if they were actually attached to the car. J/K from another former E39 M5 er.
Old Jul 12, 2006 | 09:57 AM
PorschePhd's Avatar
Wow, way lean up top. Looks good other wise. If you add more fuel it is going to make even more HP and TQ. It is too lean and will cause some issue if you hammer it to many times.
Old Jul 13, 2006 | 08:48 AM
EXPLICIT's Avatar
EXPLICIT is infamous around these parts
As suggested it is way too lean @ 5250rpm+.
Old Jul 13, 2006 | 02:01 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
This car is begging for more fuel. It needs to be fed with at least 60lbs injectors.
Old Jul 13, 2006 | 02:10 PM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
where did you connect the wideband...the exhaust?
Old Jul 13, 2006 | 02:15 PM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Who did the programming for this tune? That could tell us a lot.
Old Jul 13, 2006 | 04:27 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Whats the optinal air-fuel ratio, 12.0 to 1?
Old Jul 13, 2006 | 05:08 PM
giac ecu
in the tail pipe
boris
Old Jul 13, 2006 | 05:53 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
What stage kit is it?
Neil
Old Jul 13, 2006 | 05:59 PM
stage 5 zero clerance turbos
Boris
Old Jul 13, 2006 | 06:43 PM
vincentdds's Avatar
This looks like Kevin's package and dynapack. This setup got more to it with fuel upgrades.
Old Jul 13, 2006 | 06:48 PM
all he needs if hes not doing it so already is run a 5 bar like I did and my afrs dropped dramatically from low 13s to high 11s... low 12s.... I had the exact kit... and it ran awesome at 1.3 bars with 11.7 afrs....
9.66
click to view
