Diverter Valves Blown????
Old Aug 6, 2006 | 07:15 PM
Zippy's Avatar
How do you tell if your diverter valves are blown?
I used to only get "honking" during HARD driving, in between shifts near the red line.
NOW, I seem to be getting a lot more honking. I was just out driving and, for example, I heard some honking as I partially let off the gas, in 3rd, during a very moderate pull (<50% WOT). Does this sound like my diverter valves are dumping boost prematurely?
Old Aug 6, 2006 | 08:55 PM
sharkster's Avatar
he bud can you pull them out quickly and pressure test them? I've seen one or two EVER that actually got stuck slightly open. I guess not enough grease inside or something. I doubt they are but hey stranger things have happened. You're sure the "honking" isn't more an "airy whoosh" as you let off of the gas?
Old Aug 6, 2006 | 10:40 PM
PorschePhd's Avatar
The odds of popping an oring in the valves is next to none. There is not a whole lot to wear in there.
Old Aug 6, 2006 | 11:12 PM
Zippy's Avatar
Thanks for the response guys. I'm going to get a pressure test done when my intercoolers arrive. Would this test detect a bad diverter valve, or should they be tested seperately?
Old Aug 6, 2006 | 11:38 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Please give me some free education
Alex & Stephen -- I am ignorant in all things automotive, so I'm a bit confused by the difference between "honking" and the "airy whoosh" as potential signs of bad DV's. The ads I see for new DV's usually talk about eliminating the "honking" that you can get with the factory Bosch DV's, so I would think that "honking" is a sign of failing DV's? Would the "whoosh" sound be escaping boost (normal or abnormal?)?
Please try to excuse my ignorance, but I'm just curious as I plan on replacing my Bosch DV's with better ones soon, and I figure if I screw it up and have some leaking hose -- how will I know? I have an '01 996tt, and I hear neither a "whoosh" or "honking" currently.
Old Aug 7, 2006 | 10:56 AM
PorschePhd's Avatar
Air whoosh is normal. Remember that when you throttle off all the air built up in the system releases from the valves the minute you throttle off. The honking noise is generally caused from the factory DVs splitting the rubber diaphragm and vibrating past the split in the rubber. It honks verses a whoosh.
On the factory DVs, it is not if they fail but often when.
Old Aug 7, 2006 | 11:14 AM
Alpha's Avatar
Stephen -- Thanks for the education. I just noticed that Zippy has your IA GT700 upgrade, so he (and you and Alex) was (were) talking about his billet DV's, and not my poor quality factory DV's. Sounds like you are saying the billet type DV's rarely if ever fail, and the factory ones almost always do. Any recommendations on where to buy the billet type DV's (EVO or Bailey's?)?
Old Aug 7, 2006 | 11:17 AM
PorschePhd's Avatar
You are correct.
Where to get them.... I bet I can help with that
Old Aug 7, 2006 | 11:21 AM
Alpha's Avatar
Yes you can Stephen, just checked out your website and saw them listed for sale. Thanks.
Old Oct 3, 2007 | 01:12 PM
mmmmm's Avatar
mmmmm is infamous around these parts
Does anyone have a sound clip of the honking? I occasionally hear a screech when I shift from 1 to 2 not all the time.
Old Sep 5, 2008 | 09:26 PM
scatman200's Avatar
scatman200 is a jewel in the roughscatman200 is a jewel in the roughscatman200 is a jewel in the rough
Tonight my car started making a "hooting" sound, rather a "honking", I'm now only making .6 bar compared to the usual .7-.8? Failed DVs?
Old Sep 6, 2008 | 01:05 AM
raidentech's Avatar
raidentech is infamous around these parts
Usually a check engine light will be on when the diverter valve fail.
Old Sep 6, 2008 | 02:56 PM
I pressure tested my car ans the DVs were both leaking bigtime...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 6, 2008 | 03:04 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
ok this is the last time i'm asking... my car used to make the grear wooosh sound . then i added the larger fresh air intake sys ... (starts behind the airbox and runs o the turbos. the car is way faster buuuuuut the great woosh sound is gone not a hint of woosh whats the deal???
Old Sep 6, 2008 | 06:41 PM
Alpha's Avatar
Markski -- What type of DVs did you have that were leaking?
