6speedonline's official 60-130, 1/4 Mile, and Standing Mile list
Old May 1, 2009 | 01:41 PM
  #1771
Divexxtreme's Avatar
Guys,
Mike (TTboost) ran a very quick 6.24 with 1-shift on a 2.28% decline in his AWD car on pump gas with meth injection.
He also ran a very solid 11.54 @ 129.4 1/4 mile with a 2.02 short time.
Great job, Mike!!
Old May 1, 2009 | 01:45 PM
  #1772
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Great times on pump! And with all of that MPH at the end with a better 60 foot time I would say at least half a second would drop off the ET's.
Old May 1, 2009 | 01:55 PM
  #1773
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I completely agree - this pass was also on a 90+ degree day. Slip says 86f, but knowing the where he was it, its usually even hot on track.
Congrats.
Old May 1, 2009 | 02:01 PM
  #1774
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Congrats, Mike!
You've built a beast!
Also congrats to Tony @EPL for creating the tune to help get you there!
Nice work!
Old May 1, 2009 | 04:20 PM
  #1775
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Mike that is impressive! I'm sure you can get that 60' down.
Old May 1, 2009 | 04:34 PM
  #1776
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
I went just for kicks last weekend to the 1/4 mile event here , and on low boost 1,1 with pump gas and not the best start I got 11,6 @ 140.6 (track ticket said that) (we are @ 8500 ft above sea level)
Will learn how to use the Pbox to try and get some times....
Old May 1, 2009 | 05:53 PM
  #1777
ttboost's Avatar
Thanks Scott and everyone else! I probably could do a little better at the track, but I'm not interested in breaking any axles. I basically let the clutch out and stomped on it. The car ran flawless, as usual, in less than optimum weather.
It was my goal all along to try to maximize the 18G's on PUMP gas and try to build a 600whp pump gas car and with Tony's help, I think we're there. Well, close enough for me, for now.
Old May 1, 2009 | 07:24 PM
  #1778
MBailey's Avatar
Very impressive Mike!! I think you must be at or over 600WHP!!
Old May 1, 2009 | 08:40 PM
  #1779
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Congrats Mike!! With a good 60 ft. you can be high 10's or low 11's. What boost are you running with meth?
Old May 2, 2009 | 05:38 AM
  #1780
ttboost's Avatar
Thanks guys. Not quite 600awhp, but close enough. I am running about 1.35bar on pump with 100% Meth right now.
Old May 2, 2009 | 06:51 AM
  #1781
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Very impressive Mike. That meth really works huh? Congrats.
Old May 2, 2009 | 08:52 AM
  #1782
art4iza's Avatar
I assume you did not go with HSF if it's 100% Meth. Were you guys able to look at the dyno at that boost with and without Meth, just curious. Also interested to know the intake temp. variance. Great results!
Old May 2, 2009 | 10:52 AM
  #1783
ttboost's Avatar
Thanks Todd. Yeah I think it works VERY well. I noticed a HUGE improvement in top end as it helps carry the power out farther. I used to run out, now I have an additional 35whp after 6k or so.
Yeah Art, I used the Aquamist HSF-1 kit. Installed it myself, about 6-8hrs or so. Tony documented all the dyno data here...
https://www.6speedonline.com/forums/...ow-soon-4.html
Old May 3, 2009 | 09:10 AM
  #1784
RS38's Avatar
RS38 has a spectacular aura aboutRS38 has a spectacular aura about
do we have some 0-300 or 100-300 kph (186 mph) standings?
Old May 3, 2009 | 10:01 AM
  #1785
RS38's Avatar
Originally Posted by houstonT
3.53 sec. 60-130 for the TT Gallardo... Almost 1.5G's of longitudinal acceleration...
A few things of note...there were 2 shifts during the run, the 3-4 shift cost about 2 tenths, or more... I bet this car would have run a 3.3 or faster had he rung out 3rd gear another 100 rpm or so. Also, in 3rd gear it was making almost 1.2G's...simply nuts. Lastly, if you go back and look at the 3-4 shift, you can see that by the time he hit 130, the car hadn't even recovered from the shift as the G's were still rising. This car still has 100 rwhp left on the table, with speed dependant boost, a bit more power and no shift from 3-4, it could run in the 2's......
great performance and sound!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
