6speedonline's official 60-130, 1/4 Mile, and Standing Mile list
Old Nov 29, 2006 | 06:45 PM
  #76
VRAlexander
Guest
Posts: n/a
Originally Posted by Jean
VRAlex,
I know you understand that 1) being a Protomotive car and 2) the fastest run, I need to be more thorough with you than with any other, for obvious reasons.
This 5.9s. 2 shift run is 100% good. Damn, you got me thinking of upping my boost now
Re. your quartermile run, 11.6seconds@141mph tells the whole story! (BTW lousy 60ft in 2.6s and 0-60mph in 4.25s. !) The car has been loosing traction throughout. Still makes it the fastest trap for a 996TT.
Congratulations!
Thanks Jean,
Maybe you will have the same problems that I am having when you up your boost (AX-22 will not respond correctly)....remember that 5.9 run was done with two people and 1.3bar of boost on 19inch P-Zeros...as for the 2.6 60-foot time (now you can see how she can run a 9second even at 1.3bar on a 1.7 60-foot), I just don't have the heart to pull a "Bobby" on this car on the street...any harder launches and its in-voluntary U-turn time when I hit 2nd gear...Thanks for your time and analysis!
Old Nov 29, 2006 | 07:28 PM
  #77
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
Originally Posted by VRAlexander
Thanks Jean,
We look forward to seeing you run a 9 second pass at our drag day this Saturday, that way you can finally silence all of the nay-sayers
Old Nov 29, 2006 | 07:37 PM
  #78
VRAlexander
Guest
Posts: n/a
Unfortunately I will not be making Saturdays event ....maybe you can make a 9 second pass in one of your beasts! Do you want to come to Las Vegas for a New Years Day drag event?....you can see her run 9s then...
Old Nov 29, 2006 | 07:56 PM
  #79
acs-3's Avatar
acs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond repute
So for now, I like to share the 5.9 60-130mph(with two peolpe and 1.3bar of boost) and have Scott added to the list....this run was 2 seconds slower than my fastest 60-130mph...
Wow, still amazing numbers, your time is now the fastest on this forum
Please post the graphs ASAP
Old Nov 29, 2006 | 08:07 PM
  #80
Post a video (of the non-grainy, non-nighttime, non-freeway type that doesn't cut off right before the time shows). I figured that you would have a prior commitment on the 2nd.
Don't worry...my 9 second slip and video (both legible) will be on the forum on Sunday.
Old Nov 29, 2006 | 08:09 PM
  #81
VRAlexander
Guest
Posts: n/a
Thanks..here is the Graph...notice the tire loosing traction at the top of third (throttle modulation and the graph line)
Name:  11.6@141 @1.3bar.JPG
RennTechV12-
Like I said before when you announced the Dec. 2nd event...I had a prior commitment...good luck on Saturday and be safe...looking forward to your 9second Video on Sunday...
Old Nov 29, 2006 | 08:12 PM
  #82
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
FWIW, I hope BOTH of you run 9 second passes, and post about it for all to enjoy. Meanwhile, my car sits around gathering dust while I am stuck in the purgatory known as Oakland, California.
Craig
Old Nov 29, 2006 | 08:26 PM
  #83
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
Would anyone be generous enough to loan me there ax-22 or driftbox so I could record and post some numbers? I have a stage 2 with a rwd conversion,
Old Nov 29, 2006 | 08:28 PM
  #84
VRAlexander
Guest
Posts: n/a
Check your PM
Old Nov 29, 2006 | 08:29 PM
  #85
We'll have it at Speedworld on Saturday, and will be letting folks use it for runs on the strip
Old Nov 30, 2006 | 12:16 AM
  #86
Divexxtreme's Avatar
List has been updated. Good job, guys.
Old Nov 30, 2006 | 10:20 AM
  #87
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
I see a 6.15s. run for DMK on the list of fastest 60-130mph. With how many shifts was the run done please and what gears were used.
Edit: Weight of the car?
Old Nov 30, 2006 | 01:28 PM
  #88
VRAlexander
Guest
Posts: n/a
Did'nt you verify that run Jean???? I am under the assumption that all the runs posted here needed to be verified by you??
BTW: what did you think of that 5.34 60-130mph single shift run that I sent you from the other night???
Old Nov 30, 2006 | 02:41 PM
  #89
Jean verifies AX-22 runs. KPG verifies Driftbox runs. That was a Driftbox run.
Old Nov 30, 2006 | 02:44 PM
  #90
VRAlexander
Guest
Posts: n/a
Thanks for the info...I stand corrected!!...could we see the graph for comparison ?
Thanks.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
