Washer Fluid Reservoir Leak... how do I access it?
Old Aug 12, 2006 | 06:29 PM
achilles99's Avatar
achilles99 is infamous around these parts
So, my low washer fluid light came on. I tried to fill it up, and washer fluid poured out from somewhere under my car around the driver's side front tire. I'm assuming I have a leak or crack somewhere. Is there an easy way to check this, or is their a common fix? Thanks!
Old Aug 14, 2006 | 06:51 PM
achilles99's Avatar
You all won't believe the answer to this problem... the dealer must have removed the inner wheel liner at one point, and the tech put an extra screw to hold the liner in. The screw went straight throught the reservoir! I ended up putting silicone in the hole, and putting a tire patch on the outside of it. So far, no leaks.
mmdht2
Cayenne 958
Mar 29, 2016 12:33 PM
AdamNoone
Sep 3, 2015 04:12 AM
