Stuck Rim
Old Aug 14, 2006 | 02:52 AM
secc911's Avatar
secc911 is infamous around these parts
Stuck Rim
I would appreciate anyone's help on this. I am trying to remove my rims and the right front is stuck on the hub. I have loosened the lug nuts and lowered the car so the weight might break the adhesion with no luck.
Has anyone else had this happen and what did you do?
Thanks.
Old Aug 14, 2006 | 02:57 AM
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
Rubber mallet.
Old Aug 14, 2006 | 09:28 AM
woolyg's Avatar
woolyg is infamous around these partswoolyg is infamous around these parts
Happened to me....
As stated above... Rubber mallet did the trick..
Old Aug 14, 2006 | 10:28 AM
crazy1323's Avatar
crazy1323 is infamous around these parts
ALOT of wd-40 and try the weight trick again. If that doesnt work then beat the crud out of it with a rubber mallet
Old Aug 14, 2006 | 10:55 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Flying Karate Kick usually does the trick.
Old Aug 14, 2006 | 11:34 AM
secc911's Avatar
I've only thrown punches at it so far. I'll try the kick thing next.
Old Aug 14, 2006 | 11:40 AM
Nice1
Old Aug 14, 2006 | 01:36 PM
secc911's Avatar
The flying side kick worked!!! Or... maybe it was the rubber mallet. Either way, thanks for all the feedback!
Old Aug 14, 2006 | 02:10 PM
PorschePhd's Avatar
Yes, the simplest way is to stand behind it and kick it like a mule. Kick the bottom and it pop right off.
Old Aug 14, 2006 | 05:35 PM
t2_996420's Avatar
t2_996420 is infamous around these partst2_996420 is infamous around these parts
I run into this problem ever year at least twice when I change to winter setup and then back to summer - get a FIRM grip on the upper part of the rim toward the inboard side and pull like heck - it will loosen then you can shake it back and forth to get it loose - be careful not to force to hard and chip your caliper paint........seems like the mule kick worked out ok though!!
Old Aug 14, 2006 | 08:42 PM
iLLM3's Avatar
LOLLLL
s6spd
Oct 6, 2015 08:20 PM
Oscar 987
Sep 29, 2015 04:57 PM
manfred@loma_wheels
Audi
Sep 26, 2015 07:49 AM
Goonie
Sep 25, 2015 06:34 PM
