manual key not working?
Old Aug 16, 2006 | 02:11 AM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
i should've known - the car has not a problem for 2 weeks - a record...
i've been in chicago for 5 days and now the car won't unlock. i read the FOB turns itself off after 5 days but you should be able to unlock the door manually.
as luck would have it, this doesn't work. i turn the key in either direction and - nothing. (even if i had a dead battery (no reason though for that), the manual lock should work, right?)
any ideas?
- chuck
Old Aug 16, 2006 | 12:48 PM
carendt242's Avatar
anyone?
is there any way to re-activate the FOB?
Old Aug 16, 2006 | 01:37 PM
wross996TT's Avatar
I am happy to respond, however I don't know what to say...It should work mechanically...To reset the key FOB, you remove the battery, place it in backwards for 10 seconds and then re-install. If it needs re-programming you must see the dealer. So none of your keys work on eithet door?
Here is a link to some other ideas including fuse problems:
http://www.renntech.org/forums/index...inoperable+key
Old Aug 16, 2006 | 02:17 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
Sorry to hear that. Once in a while mine wont respond and I just keep turning it (2-3 times)
And eventuallly it unlocks. Im sure youve tried this though. good luck.
Old Aug 16, 2006 | 03:00 PM
carendt242's Avatar
wross996tt - thanks for the link & info.
rwm514, i have tried a few times but i will try again.
basically, i am reduced to breaking the window. it's in a garage, parking brake, on; etc so no one wants to touch it for < $400. a lot less headache breaking the window (and believe me, i will take *a lot* of joy in that) and driving it to get fixed.
yes, it looks good, it's very fast, and i've got way too much money into it now; but i don't think there will be another porsche turbo in my future. the past 8 months experience have been beyond taxing...
- chuck
Old Aug 16, 2006 | 03:13 PM
sharkster's Avatar
James mentioned there's some stereo stuff going on in there (I don't believe it was factory installed) but there's got to be something drawing current and killing the battery. I know that even when the light is blinking (alarm) the battery can still be too weak to open the trunk but still. I take it the trunk button doesn't work either? But damn, never heard of it not unlocking??! Before doing anything drastic give Brian a call @ Carlsen and let's see if he's ever heard of this before...
650-701-9200
Old Aug 16, 2006 | 03:16 PM
carendt242's Avatar
yep, talked to him - he said they could fix it *if* i could get it down there. obviously, that's the trick since no tow truck company will touch it right now.
can't get into the car so don't know if it's a battery or anything. brian said the manual key should still work, even if the battery is dead. this makes logical sense but i guess i wouldn't put anything pass the designers of this car...
- chuck
Old Aug 16, 2006 | 03:18 PM
sharkster's Avatar
- chuck
Gotya. I understand- the hand brake is on so they're obviously leary Getting to the starter motor is nigh on impossible too.. for using a +-ive connection. The hood doesn't open either obviously with the button on the key- even with a new battery, right?
Old Aug 16, 2006 | 03:35 PM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
Do porsche windows have frames? I had a locksmith break into my car (frameless windows) by inserting a balloon past the edge of the window and inflating it, then reaching in with a metal pole and triggering the door lock. Kind of disconcerting, really. It only took him like three minutes to get into my car.
Old Aug 16, 2006 | 04:04 PM
carendt242's Avatar
well, will start trying locksmiths...
Old Aug 16, 2006 | 05:22 PM
carendt242's Avatar
gramicci101, thanks for the tip. armed w/ that little knowledge, i was able to find a locksmith who could open the door.
they used this tool
http://www.northerntool.com/webapp/w...&cm_ite=safety
note: this won't work on 993tt's - there's one next to me in the garage and they have frames around the window.
- chuck
Old Aug 16, 2006 | 05:25 PM
Kind of sucks, doesn't it. I was like, damn, it shouldn't be that easy to get into my car. WTF.
Old Aug 16, 2006 | 06:18 PM
sharkster's Avatar
they used this tool
- chuck
Niiice! Now let's get a real optima red top in there or something!
Old Aug 16, 2006 | 08:42 PM
carendt242's Avatar
but the battery is fine
it's just a ****ty car and its 2 weeks were up. after i get the non-working manual lock tomorrow, i got 2 more weeks til something else breaks.
- chuck
Old Aug 16, 2006 | 08:57 PM
sharkster's Avatar
- chuck
Doh Nah it'll be ok... just park it in a sunnier spot!
