Rear camber settings
Old Aug 18, 2006 | 04:04 PM
ExTex50's Avatar
ExTex50 is infamous around these parts
I have uneven tire wear on my rear tires. It's worn at the inside edge of both rear tires, I assume that means too much negative camber could be part of the problem. Current camber settings are -1.6 deg for both sides. Alignment specs from the shop says min and max range from -1.7 to -1.2, so it's in spec. I've lowered the car with PSS9's and have 315/25-19 tires on it.
Anyone else having similar wear problems and if not, what are your rear camber settings? For street driving, no track.
Mark
Old Aug 18, 2006 | 04:10 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
What do you call uneven, Is it just wear on the insides of both rear tires?
Old Aug 18, 2006 | 04:19 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I think this is just normal for Porsche to have inner tire wear like you describe. All the weight is in the rear, and the geometry of the suspension with the factory tolerance of negative camber is going to wear those rears quick. I have -2 degrees with PSS9's at ROW height, and had my mechanic dial in that neg camber to prevent any tire/fender rub with my 315's in the rear. Plus the car handles so well.
Old Aug 18, 2006 | 04:32 PM
Agreed! This is normal, his setting seem correct! I think it just pisses ppl off when they think they have good tires until the see the inner edges. Mine were through the canvas on insides.
Old Aug 18, 2006 | 04:54 PM
ExTex50's Avatar
Yes, it's uneven in that it's almost down to the the cord on the very inside edge, about where the tread meets the sidewall. The outside of the tire still has plenty of tread, maybe 5/32 left. This is my first 911, maybe it's normal. Just seems a bit extreme.
Mark
Old Aug 18, 2006 | 05:24 PM
Joe Weinstein's Avatar
Your camber is at the max recommended, so adjust it for less negative
camber. Also, figure out how many miles you've run to wear them down
so far, and then, when you get new tires, after about a third of that
distance on the new tires, go to your tire shop and have them dismount
and remount the tires inside-out so you get more out of them.
Think of the issues I have: I run with 2.7 degrees negative!
Joe
Old Aug 18, 2006 | 05:36 PM
Zippy's Avatar
Mark, you can always balance your tire wear, and take advantage of your current cabmer setting, by being much more aggressive in the corners.
Old Aug 19, 2006 | 04:31 AM
kiko's Avatar
kiko is infamous around these parts
What he saiD!!!
Old Aug 19, 2006 | 04:36 AM
He Kiko, these settings (especially front of car) you passed to me are awesome!
Thanks again mate
Suspension set up: Kiko is your man.
Old Aug 19, 2006 | 04:51 AM
kiko's Avatar
Glad you're happy Steve. The more you get used to the cars new handling the more you'll enjoy it, get the GT2 rear bar for neutral handling making throttle steering a joy.
P.S. Since the toe is on its limits therefore on the verge of maing the car darty don't forget to check the toe (easy and inexpensive 2 wheel alignment no need for the complex Porsche routine) now and then, every 5k miles or so depending on the use.
Old Aug 19, 2006 | 05:31 AM
i have exactly the same set up.... same rims and tire size... and the pss9s....
I had had it at -2.1 and had the car redone to -1.8 camber... but I still get considerable tire wear.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 19, 2006 | 04:46 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
What is ROW height anyway? How much drop (F&R) from standard US height?
Old Aug 19, 2006 | 08:22 PM
tom kerr's Avatar
Mark, that is normal and "the way it goes" for this car if properly set up. I would do what Joe recommends. I usually switch my tires side to side several times before new ones and you avoid the inner wear through for quite some time like that.
Old Aug 19, 2006 | 08:32 PM
Even though they are one directional ?
9.66
click to view
Old Aug 19, 2006 | 08:38 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
yah, my contis have "inside" and "outside", so I dont think you'd want to switch them around. Inside tire wear is completely normal though.
