Stock Spoiler Help
Old Aug 24, 2006 | 07:32 PM
ritchieswimwear's Avatar
ritchieswimwear is infamous around these parts
Stock Spoiler Help
My spoiler is going only half way up manually and I am getting a spoiler failure warning light. Does anyone have a tinker suggestion before I go to the dealer, thanks
Old Aug 24, 2006 | 07:45 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Ritchieswimwear, I am going through the exact same thing right now.
https://www.6speedonline.com/forums/...ad.php?t=56667
I tried disconnecting the battery for 10 minutes...no luck
I have now pulled the fuse for now....it is row d and #7 and it is 15 amps.
I am going to try to figure out what is wrong. It seems like the hydraulic fluid is going to the drivers side faster then the other side. I can lift the passenger side to the correct height, but it just drops with the negative pressure in the actuator.
Old Aug 24, 2006 | 10:05 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
I also have the same issue with my spoiler. I believe it is a hydraulic leak in the driver's side ram. You can check for leaks by opening the engine bay and popping off the plastic cap from the bottom of each ram. If there is an oily substance at the bottom, you may have a leak. The ram can be replaced, but the bleeding process is quite elaborate (total PITA I hear) and the other ram may then fail. I think replacing the whole drive system is easier. This is more expensive, and depending on the model year of your car, you may also need to replace the instrument console and relay #9 as there are two different spoiler drive variants between MY 2000 and 2002.
Old Aug 24, 2006 | 10:07 PM
tom kerr's Avatar
? viagra????
COBB Tuning
Jan 1, 2025 09:02 AM
Lowtush
Jan 25, 2022 10:48 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
SharkyShark20
Sep 19, 2015 09:54 PM
Sales@RSW
Sep 3, 2015 09:34 AM
