Does the X50 have a different exhaust?
Old Aug 5, 2003 | 02:39 PM
  #46
EM 996 GTS's Avatar
EM 996 GTS is infamous around these parts
Originally posted by racer63
Along these lines, I found this on the internet. This guy took it farther than I would have the patience to do... but the same concept.
http://www.svttexas.com/Tech/PDF/dynamat.pdf
WOW ... that's gonna cost a BOMB on the Turbo!
I think I'm changing my mind about installing that...
I might as well go for Stage4..
do you recomend that EVO stage4 kit?
Old Aug 5, 2003 | 03:47 PM
  #47
racer63's Avatar
racer63 is infamous around these parts
I wouldn't go nearly to the extent that this guy did... His approach looked like overkill to me. I was thinking of just adding some sound proofing in the back end of the car, around the area that separates the engine compartment and the cockpit.
I highly recommend the stage 4gt. Phenominal acceleration, yet more driveable than stock (less lag, better responsiveness). My car dynoed at 540 rwhp and runs like a scalded cheatah. The guys at EVO are also very knowledgeable and offer extremely good service. My best aftermarket experience by far.
Old Aug 5, 2003 | 03:56 PM
  #48
911 X50's Avatar
911 X50 is infamous around these parts
Just cancelled the Techart 'sport' as the wait is too long.So now its back to exhaust hunting again.Does anyone know of a aftermarket exhaust that wont frighten old people,kill wildlife,or set off car alarms from 50 paces???I dont want to go racing,just sound a little cooler cruising around the cafes LOL !!
Old Aug 5, 2003 | 05:15 PM
  #49
MTBR's Avatar
MTBR is infamous around these parts
Europipe Stage II Loud, IMO best exhaust out there.
Old Aug 5, 2003 | 05:22 PM
  #50
oak's Avatar
oak
Dan, did you ever find out where your intake leaks were? just wondering how it worked out.
Old Aug 5, 2003 | 05:56 PM
  #51
MTBR's Avatar
Had my car flatbedded to the nearest dealer. They said they couldn't find any leaks and just removed and reinstalled my MAF since the values were out of whack. Upon driving home, same problem!
I then had my car flatbedded to a different dealer. I called today and they mentioned that one of the turbo vaccuum units failed and they will be replacing it. Part should be replaced and the car road tested by tomorrow evening. We'll see how that goes.
Old Aug 5, 2003 | 11:33 PM
  #52
oak's Avatar
oak
Dan, That's strange, do you know what they meant by vacuum units? There are no vacuum units on the turbo, unless they meant the diaphram for the waste gate actuator?? That's the only mechanism that is operated by vacuum. keep me posted!
Old Aug 6, 2003 | 12:22 AM
  #53
racer63's Avatar
Hey, now... I've never killed any wildlife! Ok. I do anticipate killing a few snakes and prancing horses here and there. But, nothing on the endangered species list.
Old Aug 6, 2003 | 12:42 AM
  #54
911 X50's Avatar
i bet you anything you like if i sent you a red towel via UPS youd go picking fights with bulls as well !
Old Aug 6, 2003 | 12:44 AM
  #55
racer63's Avatar
Excellent idea!
Old Aug 6, 2003 | 01:09 AM
  #56
911 X50's Avatar
Europipe sounds good,not to sure about the 'LOUD' part though.Murphys law says if i get the 'LOUD' one it will drive me nuts,if i go for the 'Quiet' one it wont make f*** all difference and i will have wasted my time and money
Old Aug 6, 2003 | 01:56 AM
  #57
msindi's Avatar
Go with EP loud - it is not that loud from what I hear....
Old Aug 6, 2003 | 07:50 AM
  #58
MTBR's Avatar
Oak,
I believe you are correct, it is the diaphram for the waste gate actuator. Although rare, that is what they believe is causing the problem. We shall see, I hope they are correct.
Small Shrimp
Sep 1, 2015 10:51 AM
Ferrari
Aug 24, 2015 04:35 PM
Vrseis
Aug 20, 2015 07:41 AM
