Engine Oil level low warning light???
Old Sep 24, 2006 | 06:24 AM
davidTT's Avatar
davidTT is infamous around these parts
I changed the oil like 1500 miles ago, and i got the Engine oil level low warning light couple days ago....does it matter?just ignore it?or i need to add more engine oil?
Any info will be appreciated~thanks
Old Sep 24, 2006 | 07:36 AM
RCNJ's Avatar
RCNJ is infamous around these parts
My Turbo burned one quart of oil about every 800 to 1k miles. So you most likely need to add a quart.
Old Sep 24, 2006 | 09:51 AM
tthoang1's Avatar
tthoang1 is infamous around these parts
Run the oil measurement check after the car has been run. If it shows that I'm running low, I'll put enough oil to be at the mid point level. I burn about the same amount as RCNJ.
Old Sep 24, 2006 | 10:10 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Our engine burn quart of oil about every 1k was normal. But you mention oil change in 1500 miles ago. Burn to oil level low warning light was too fast. I will suggest refill oil to mid point level right now and keep check the oil level.
Old Sep 24, 2006 | 02:30 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
I advise just adding 1/2 quart at a time. These electronic monitors read all over the place at times.
Old Sep 24, 2006 | 07:27 PM
davidTT's Avatar
thanks for the info, guys...i will try to add more oil
Old Sep 24, 2006 | 11:19 PM
PorschePhd's Avatar
Run it one line over the min mark. This is safe. It is not the end of the world to be several quarts low in a dry sump system. I will not tell you what these motors will live on as far as oil, but keeping it one line up over the min is more than fine.
Old Sep 25, 2006 | 10:16 AM
kiko's Avatar
kiko is infamous around these parts
I can't say names nor locations but I know an "ARS"#$E" (Head Tech @ a dealer) who ran the engine dry to claim a new engine from the factory as the client wanted the car but beause the car had 60000miles he said he'd only buy the car id it had an new ngine...and voilá! I got seasick (honest!!! I really did) when I heard the story. It sounded like a SNUFF, they even told me the engine idled for 15min before shutting down (i.e. dieing)
Old Sep 25, 2006 | 10:39 AM
PorschePhd's Avatar
I have seen cars living with 4 quart of a 12 quart system live. Not for a week, but months and still ran when we got it in to change the oil. Dry sumps are great!
Old Sep 25, 2006 | 10:42 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
That is amazing!
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
In Turbo cars, it's important to let the engine idle for a bit after harsh or fast driving expecially in hot conditions. You are baking oil fed into the Turbo lines if you don't, this process over time will limit the amount of flow through these lines and eventually kill the Turbo. I've replaced a few Turbos in my time and I've seen this a couple of times first hand.
This baking in the lines will cause you to loose more oil than a NA.
-Eli
Old Sep 25, 2006 | 06:27 PM
iLLM3's Avatar
So wait, when the check oil level light comes on, its not that its low on oil , and how many quarts are still int he car at that time! Its odd because when it comes on, i add a quart and it goes up a few bars, meaning there's still prob. alot of oil still left, just as a safety thing right?
Old Sep 25, 2006 | 06:32 PM
PorschePhd's Avatar
It is lower than it was, but there is probably 7 quarts in the system. There is no pan for it to take a measurement. It measure the level of the stream through the tank. It is a safety thing.
Old Sep 25, 2006 | 06:55 PM
iLLM3's Avatar
Ahh ok cool, i remember i would freak out if driving it and it came on and i couldnt get oil, i would quickly take it home
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
tkebp1275
Aug 31, 2015 06:35 PM
