Racing a modded wrx tonight
Old Oct 12, 2006 | 06:12 PM
iLLM3's Avatar
Originally Posted by mt72
trap speed is right guy ... I raced againts him ....
I saw STi doing 12 high@ 115 MPH ..... I don't know about you guys maby you have seen bad drivers ?
LOLLLLLLLLLLL
Listen man, ive been around the Subaru scene, my friends had Sti's that were BUILT, WRX's you name it, they worked for Metric Subaru here in NY. Subaru WRX and Wagons are SLOW, they trap in the 90's, and low to mid at that.
My stock m3 which dyno'd in upper 280 whp range spanked a friends Sti with eccutek, turboback exhaust and a few other things, M3's trap at 105-108, stock for stock with equal drivers from a dig M3 will beat an Sti, espeically once it gets over 100mph its not even CLOSE, ESPECIALLY from a roll on from 50, believe me, ive been through it all.
Sti trapping at 115 would have to have over 400 awhp+, stock Sti's get off the line and down a 1.4 mile track fast because they are easy to dump the clutch at 5k rpm and get off the line like a bat out of hell, but for their times and trap speed you can tell from a roll it wont act as a low 13 second car, you understand? Stock Porsche 996 TT's are trapping at 115 man, and they would leave an Sti like (insert analogy) , come on man!
mt72's Avatar
mt72 is infamous around these parts
Old Oct 12, 2006 | 06:14 PM
mt72's Avatar
Originally Posted by iLLM3
LOLLLLLLLLLLL
My stock m3 which dyno'd in upper 290 whp range spanked a friends Sti with eccutek, turboback exhaust and a few other things, M3's trap at 105-108, stock for stock with equal drivers from a dig M3 will beat an Sti, espeically once it gets over 100mph its not even CLOSE, ESPECIALLY from a roll on from 50, believe me, ive been through it all.
I am not saying the 996 TT won't win I saying 115MPH is possible
EDIT here's my friend kicking m5
http://videos.streetfire.net/video/9...2e00178fd9.htm
Old Oct 12, 2006 | 06:15 PM
BLKM3's Avatar
BLKM3 is infamous around these parts
Definetely wasn't stock. Probably had aftermarket turbo to be hitting those kinds of trap speeds.
Old Oct 12, 2006 | 06:21 PM
mt72's Avatar
I mistyped in my previous post
sorry about that 13:85@107mph for the stock wagon That I raced .... but I saw more then one STI doing some great times
Old Oct 12, 2006 | 06:24 PM
iLLM3's Avatar
Are you seriously that stupid? We were debating over your WHACKO stock figures for the WRX Wagon and Sti
Car-Stats.com Report for 2004 Subaru WRX Sti
Obtained from MT June, 20030-60:
4.9
Transmission: Manual1/4 Mile:
13.2
1/4 Speed:
104
WRX Wagon is almost a 14 sec car at 95 mph, again come on man do some research.
BTW 1.6 60' time for a 500 whp Sti pulling a 11.6 is not impressive, shows how much the launch helped his time, that car ont he highway would get beat by a 550 hp 996tt!
Old Oct 12, 2006 | 06:25 PM
iLLM3's Avatar
On a STOCK STI, even with some good mods its not possible, even moreso for a damm WRX wagon man, dont you get it??
Old Oct 12, 2006 | 06:38 PM
keyser_soze's Avatar
keyser_soze has a spectacular aura aboutkeyser_soze has a spectacular aura about
I have an Impreza WRX STi. and here it is:
I have every bolt-on and still in process of fully tuning the car. So far I've ran on my base tune 12.8@109.98 MPH (2.0 sec 60ft! most likely due to dying clutch) on pump gas 17lbs of boost. My setup (as demonstrated by few of my friends with identical mods) is capable of 11.5@122 MPH on non-lead race gas 28lbs of boost tapering to 24. I am planing to do this before the winter hits hoefully.
Now to the wagon and regular WRX and stock STi. I've been around them as you can imagine. IMHO stock wagon will run high 13 sec pass @ barely 100 MPH on AVERAGE. WRX similary maybe a bit faster, and stock STi's low 13s maybe very few very high 12s all in the 101~104 MPH range.
Cheers.
P.S. Regarding the horrible 60ft, I've had alot of 1.6~1.8 before, the 2.0 could be due to the increase in power and dying clutch. Its stock clutch with 50~60 passes on it)
Old Oct 12, 2006 | 06:55 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
When I was at the drag day event last year and did a 12.1 @119 there was a 06 wrx sedan stock except for a ecu flash. If I remember right he was running 14.4 at 94mph. It looked pretty ridiculous out there with all the fast cars.
Old Oct 12, 2006 | 06:56 PM
I have an Evo8.. although it does low 10s... I do run it on low boost as well.
My car on low boost-(20 psi) runs even if not a bit faster(1 car )... and that was against a X50.
IF the guy has a decent size turbo, 20 psi, good gas, maybe its a little lighter??? I think it will not be a big blow out either way. but if he doesnt know what hes doing, like most guys do not, then hes done. I believe it can be done with the right tuning and or bolt ons....
My evo tuner ran a stock motor and did 10.8 @128 mph. but thats an evo...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 12, 2006 | 07:07 PM
mt72's Avatar
can't you read properly before insulting people ?
Old Oct 12, 2006 | 07:11 PM
mt72's Avatar
4.9
13.2
1/4 Speed:
104
maby you got me wrong or something nevermind
porsche nevar loose
iLLM3's Avatar
I appologize if i am being "insulting" .. But please do read your previous post's, and if its not what you mean then make yourself more clear, we were talking about a stock WRX Wagon, then you say Sti, leading me to believe your saying a stock Sti was trapping 115's, if not, tell me that it was modded and had 800 hp or w/e, understand?
Stock WRX wagon run arround 13:05@107-108
if he got stock internals with big turbo them he'S not boosting more 15psi so not more then 12:80@115MPH
so you should be ok depending if as forged is engin
my 2 cents !!!
Old Oct 12, 2006 | 07:17 PM
mt72's Avatar
ya for the wagon I mistyped it was 13:85@107MPH
also said that STI with stock internals with bigger turbo could not run very much over 15psi wich can easy achieve 12high@115MPH .... I have 257WHP and I trapped 113MPH with my all motor .... so don't tell this is not achievable
Old Oct 12, 2006 | 07:18 PM
iLLM3's Avatar
also said that STI with stock internals with bigger turbo could run very much over 15psi wich can easy achieve 12high@115MPH .... I have 257WHP and I trapped 113MPH with my all motor .... so don't tell this is not achievable
Its not, and WRX wagon runs nowhere near a 107 mph TRAP LOL, i just dont understand, what dont you get?
