A good boost gauge.
A good boost gauge.
Who has custom boost gauge in the car? And what is a good one that reads psi. Any of you guys got the kind that tells you what boost your last run was?
Thanks.
Thanks.
www.zeitronix.com
displays four variables (boost, egt, lamda, and AF). has peak hold. can also be hooked up to a laptop to datalog and graph the above mentioned four variables, as well as TPS, RPM, and something else I can't remember.
i've been using it for a while now. great unit and the most useful of the bunch. not to mention it's a value compared to the defi stuff.
Originally Posted by topgun
DEFI!! w/ the controller you can record three minutes of data, you can set
peak warnings & see your highest peak!
Good Luck
Good Luck
What gauges do you have (Eg. Boost?) Who installed them?
TIA
JAg
TIAJAg
TIAJAg
Stock boost guage is not that accurate & doesn't hold peak!!!
Oh and what did you do with your HVAC controls?
Originally Posted by tblackj
Also, is that panel in your center console an "off the shelf" item or did you have it built?
on top I did not touch them!!! here are pictures before & after!
