Current/Former E46 M3 Guys Chime In
Old Nov 5, 2006 | 01:32 AM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Thumbs up Current/Former E46 M3 Guys Chime In
Horsepowerfreak recenttly announced the completion of their Turbo Kit. Sounds very promising. Will this have any chance against the big boys 996TT?
Originally Posted by HorsepowerFreak
520rwhp - 400ft-lbs at 8psi.
We were able to figure out some things and get a couple more pulls on the dyno today. We turned the boost up one more pound to 8psi and made 520rwhp, 400ft-lbs. We still have a LOT more tuning to do, and we're going to run a LOT more boost.
Here's a video of our M3 on the dyno during one of the pulls.
http://www.horsepowerfreaks.com/vide...hp8psiDyno.wmv
Here's a video inside the cabin during a subsequent pull. You can see the nice gauge pod with UEGO wide-band and Boost gauge that will be included with every kit.
http://www.horsepowerfreaks.com/vide...DuringPull.wmv
Take care,
Chris.
Old Nov 5, 2006 | 02:16 AM
crazy1323's Avatar
crazy1323 is infamous around these parts
I am an E46 guy but I don'n own an M3. However over on e46fanatics HPF is claiming to be running 8psi (a little more than .5bar) and getting like 530RWHP with a 8000 RPM redline and stock internals. They are now planning on seeing how far the stock internals will go before needing new gaskets, pistons, and rods. They are planning on testing 15 psi (a little more than 1bar) and also testing 20psi with a BB terbo. here is the link
http://forum.e46fanatics.com/showthread.php?t=414872
put is this way, if you hear a PSSS sound coming from an e46 M3, run an hide unless your name is Craig, VRalexander, or Mariski. And they need to be careful with anything running 15psi and a built motor.
Old Nov 5, 2006 | 03:07 AM
eshaun's Avatar
eshaun is infamous around these partseshaun is infamous around these parts
thats great they are pushing the limit, but personally coming from a turbo car (sti) I wanted something with a nice smooth high revving n/a powerband and thus chose the m3. I wouldnt toy with this motor at all given the history of the early m3's. The stock power really is plenty for most DE stuff and sitting in SF traffic lol...If I opted to go FI at some point in the future, id probly go with an s/c setup.
Old Nov 5, 2006 | 04:58 AM
Divexxtreme's Avatar
They are actually claiming 533 rwhp at 8 psi, which is almost double the M3's stock HP at only 8 psi. I, as well as others on M3forum, have asked them how this is possible...since I thought in order to double the power of an engine..you needed double the air intake. Which would mean 14.7 psi or so (100% of atmosphere). I realize the car has high compression..but it still doesn't seem possible to nearly double it's power at only 8 psi (54% of atmosphere).
We asked the question a few days ago, and they have not responded as of yet.
Old Nov 7, 2006 | 09:45 PM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
I think it would take away from the car's true soul..and yes...it has a soul...
Old Nov 7, 2006 | 10:18 PM
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
I'm not scared of it...bring it on!
Old Nov 7, 2006 | 10:27 PM
LUISGT3's Avatar
M3 with 15 PSI on stock internals =
iLLM3's Avatar
If you think that is impossible Scott, you should hear his plans that he has been exchanging back and forth with me on e46 via pm's, insanity. I was thinking about doing it, then i realized, our platform is FAR superior and i would be an idiot to take a step back, although i want another m3 badly as a daily, not as a project/FI car, it will have power, but SEVERE issues with traction and in every other category!
Old Nov 7, 2006 | 11:40 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
I have had a few e46 m3's- great cars..
Are these guys dropping the compression on these engines, running sodium filled valves for heat? Or is this a bolt on kit.........?
Thats a ton of HORSEPOWER to make with only 8psi of boost.
They may make 500+ rwhp but for how long?
Dont get me wrong the m3 is great car - But I have yet to see someone make a real reliable kit.. It would be really nice if this is the first one..
Time will tell..
Old Nov 7, 2006 | 11:42 PM
Im with you... Bring it......................
Old Nov 8, 2006 | 12:54 AM
iLLM3's Avatar
Time will tell..
Nothing but a bolt on kit, 530rwhp/650 crank isnt where he is stopping for stg 1 and on stock bottom end too, hes going higher, way higher before offering the stg 2 which is with a build!
Old Nov 8, 2006 | 08:49 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Had an E46 M3 - girl in the Avatar has one now - great cars -
Bring it on - I would love to race 'em at Sebring in my tt.
Old Nov 8, 2006 | 09:01 AM
yellowturbo's Avatar
yellowturbo is infamous around these parts
Reliability will always be what needs to be in the forefront so it would be interesting if any issues are encountered. Also, when and where on the graph is the HP/TQ coming in and is it flat or very peaky? I'm sure a 600HP turbo M3 can be developed, but if it can't keep up with a 500HP car in the real world, what's the point (unless only dyno numbers are important)?
By the way, I don't get these dyno videos...it shows a car standing still with no meters, etc.
Old Nov 8, 2006 | 01:41 PM
crazy1323's Avatar
You have to remember that the M3 has a 8000 RPM redline which some even raise as high as 9000. There is alot of room to work with when you can rev that high. Even with a big turbo you still have plenty of time before you have to shift. Like I sais and Martin (illm3) will agree, the stage two with a built motor and 15psi will be sick and dangerous for TT's. He also has plans of going even higher, till the motor busts probably.
Old Nov 8, 2006 | 01:50 PM
vincentdds's Avatar
Who's the "Protomotive" of the M3 world that can build the motor and slap on the Turbos?
