Header question.
Old Nov 10, 2006 | 08:07 AM
Indykid's Avatar
Indykid is a jewel in the roughIndykid is a jewel in the roughIndykid is a jewel in the rough
Header question.
How much power if any does a header add if you are 600hp (crank) or under? I had a tuner tell me that it doesn't really do much until you're over 600hp. Any thoughts?
Old Nov 10, 2006 | 08:37 AM
cjv's Avatar
cjv
Moderator
It is not really one of the weak links on the 996tt at 600 hp.
Old Nov 10, 2006 | 12:00 PM
Eric523's Avatar
Eric523 is infamous around these parts
I have been told the same
Old Nov 10, 2006 | 12:31 PM
tom kerr's Avatar
below 600 hp not a great upgrade. what would be worth while is having your current set ported and ceramic coated.
Old Nov 10, 2006 | 08:48 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
Yeah, an hour with a dremel tool can buy you 5-7 hp, I'm not a fan of ceramic coating....some good, some bad aspects.
Old Nov 10, 2006 | 08:54 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
have heard the same take a drummel to them... kevin sez its so. so it must be....i have s cargos large tube headers (was a scared to bend a rod) .. asks alex about that..... oh thats why no small tube headers....
Indykid's Avatar
Okay so explain this......several tuner show a 50hp gain between stage 3(550hp) and stage4(600hp). 3 without headers and 4 with headers. Are they just adjusting the fuel/boost levels? So what is the purpose of the headers?
Old Nov 10, 2006 | 10:00 PM
stock headers must be debured (drummel work) they are small tubes and will help you 16s spool up faster. s cargo headers are a different design the larger tubes will allow a smother constant flow (more air more power) the smaller will compress the air and allow a better flow.... i would think better with a k24 set up....have heard of bent rods with the smaller tubes.... my thoughts only opps forgot to mention s cargo has a different design tube configuration....
Old Nov 11, 2006 | 01:50 AM
yellowturbo's Avatar
yellowturbo is infamous around these parts
I keep hearing bent rods mentioned at several points in the forum - so anybody willing to come out and confirm (along with what they were running when it happened)? Did this happen above 700 (GT700 and equivalent) levels with stock internals?
Old Nov 11, 2006 | 04:33 AM
The guys who bent the rods were running too much boost...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 11, 2006 | 08:09 AM
Indykid's Avatar
Anyone, anyone?? What is the boost level difference between stage 3 and 4??
Old Nov 11, 2006 | 09:28 AM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
The major difference between the EVO stage 3 and stage 4 is headers and software. The headers reduce turbo lag and increase the velocity of the exhaust gasses traveling to the turbochargers which improve overall power. The software is responsible for the remaining power gain between the 2 systems. Timing and boost are increased to improve power from the 550 HP to 600 HP. Boost goes from ~1.0 - 1.1 bar (stage 3) to ~ 1.2 bar (stage 4). Torque is also substantially increased from the more efficient headers and a more aggressive low to midrange boost curve. This programming change improves the overall torque as well as shifts the torque curve down lower in the RPM range making the engine more responsive. Hope this helps.
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Nov 11, 2006 | 09:40 AM
MX RACER's Avatar
MX RACER is infamous around these parts
Todd, I was told the programing for stage 3 and 4 is the same is this not true????
Old Nov 11, 2006 | 09:46 AM
Not the same
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Nov 11, 2006 | 09:54 AM
MX RACER's Avatar
Originally Posted by Todd @ EVO
Not the same
Todd I was told by you guys it was.. I sent you an e mail..
George
