Forge Diverter Valves
Old Nov 14, 2006 | 11:21 AM
iborroel's Avatar
iborroel is infamous around these parts
Which spring should be used in the Forge diverter valve on a 996TT with a 1bar program and exhaust?
Old Nov 14, 2006 | 11:27 AM
wross996TT's Avatar
DV springs? Not sure what that is or if it is "adjustable"? Are you sure you are not confusing DVs with Wastegates?
Seems the reason you get the billet DVs is because the stock oneaa are plastic and will blow eventually. This is not a performance upgrade, but a reliability one.
Old Nov 14, 2006 | 11:33 AM
iborroel's Avatar
wross996TT: I know the difference between DVs and wastegates. Well at least I think I do. Forge diverter valves have springs in them that you can change out for stiffer/softer ones. I was trying to see what other people around here were using if they were using Forge units.
Old Nov 14, 2006 | 01:16 PM
wross996TT's Avatar
Sorry, my bad. Never heard of them...most folks I know just use billet dvs.
Old Nov 14, 2006 | 01:25 PM
iborroel's Avatar
wross996TT: These are billet DVs but the company/brand is Forge.
Old Nov 14, 2006 | 01:27 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
I used the green spring with 2 shims for my 1.25 bar setuo pe Kevin at Ultimate.
Bill: These are user adjustable for different boost levels. Kit comes with 3 different springs and shims for fine tuning, pretty neat actually. Kevin
Old Nov 14, 2006 | 01:41 PM
wross996TT's Avatar
Yeah, I googled them, just not sure what peformance they are adding, if any? Learn somethin new everyday!
Old Nov 14, 2006 | 01:44 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Well, I can way I learned something new today also. So with these DV's, they come with different springs for different boost levels? Seems like a lot of work to change them though.
Old Nov 14, 2006 | 01:47 PM
KPG's Avatar
KPG
I found things in my other DV's that I didnt like Kevin
Old Nov 14, 2006 | 01:50 PM
iborroel's Avatar
M3CAB: Changing the actual springs isn't hard at all. Removing the DVs from the car probably is the harder part.
KPG: I don't have this issue but that's why I'm going to replace them since I don't want to find anything in the future.
Old Nov 14, 2006 | 01:53 PM
KPG's Avatar
KPG
Good choice. Kevin
Old Nov 14, 2006 | 02:02 PM
wross996TT's Avatar
So which ones do you get and where (I saw three types)? TIA!
Old Nov 14, 2006 | 02:05 PM
KPG's Avatar
KPG
Bill, they all come with the kit....Blue ,Yellow and Green. I know you are partial to Red but you cant use it I got mine direct from Forge, but I think VividRacing is having a group buy for 280$. Kevin
Old Nov 14, 2006 | 02:12 PM
iborroel's Avatar
Old Nov 14, 2006 | 02:28 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
I just got mine from Kevin UMW. He recommended the yellow springs.
