What is the next step to get more power in my GT2
Old Nov 22, 2006 | 03:06 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Driver training is a great way to get more out of your GT2..
After that...................... www.gmgracing.com
We just won the our class in the Time Attack finale in our GT2.. We won by more than 3++ seconds
Old Nov 22, 2006 | 11:40 AM
GT3RennSport's Avatar
GT3RennSport is infamous around these parts
Originally Posted by SMR
Andreas
This is what you should do
Uppgraded WG and tuned right
New DV
a BIG sevice
Ported and polisched stock headers
A lightweight flywheel would be nice to
Why doesn´t any of the big German Tuners change the DV´s and the WG´s.
Because it isn´t necessary?.
Ruf have a 590hp kit, and the don´t change any of the parts above,same goes for FVD,9ff,Techart,Manthey,Cargraphic,Gemballa.
Old Nov 22, 2006 | 11:46 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
I honestly can´t see any reason of changing WG´s on gt2 with stock turbos.
The DV are only a saefty thing and alot better, but no need for them,but if you like to change out them for stock ones now and then that is OK also, becouse they will fall...
Have you tested uppgrded WG so you know what you are speaking of...?...
Old Nov 22, 2006 | 11:53 AM
There is a big differance in adjusting and changeing the WG´s.
Old Nov 22, 2006 | 12:14 PM
SMR's Avatar
SMR
it depends how hard spring the uppgrded WG use
Old Nov 22, 2006 | 12:20 PM
SMR's Avatar
SMR
And also i did adjust my WG before and then installed uppgrded WG, what a diffrence......!
And when the UMW PP go on i can hold a steady 1,2bar instead of droping boost
orbelo
Aug 30, 2015 12:26 PM
