High Flow Air Intake
Old Feb 13, 2004 | 03:09 PM
Zippy's Avatar
I thought I heard some chatter a while ago the EVOMS was developing a high flow air intake for the 996TT. Any news on how it progressing?
Old Feb 13, 2004 | 05:22 PM
cjv's Avatar
cjv
Moderator
Zippy,
The highest flow air intake is made by S Car Go Racing. I believe EVOMS has used many of them already.
Old Feb 13, 2004 | 06:17 PM
Zippy's Avatar
The ScarGO intake (carbon fiber?) intake sounds great. I was a little concerned about the its reported brittleness. I was hoping something a little more resiliant was in the works.
Old Feb 13, 2004 | 06:31 PM
cjv's Avatar
cjv
Moderator
Zippy,
The whole units weighs but ounces. If you smack it hard with something, it will break.
Old Feb 14, 2004 | 05:38 PM
PorschePhd's Avatar
I just installed mine yesterday. The biggest issue is routing it and not forcing the unit in place. The area where it passes around the suspension is a close call. I actually wrapped that area with another piece of silicone hose. A set of hump pipes would work well with the setup rather than normal sleeve. The unit weight nothing, really. There is also a couple of halves that have to be glued, silicone etc. Nice unit, but you can not cram it or force it in to place. You will cause FOD in the turbo if you do. Also watch the drop link mount on the coilover setups. The arms often loosen up and move around. I would bet as close as the pipes are because of the diameter it would take one of these out. So watch out for that. The unit is a nice piece.
Old Feb 14, 2004 | 05:46 PM
Zippy's Avatar
How do we deal with the ECU? I imagine the intake has a flow rate than stock. Is an ECU adjustment required? Would the AFR's be a little on the lean side if not richened up a bit?
Old Feb 14, 2004 | 05:55 PM
jro's Avatar
jro
jro is infamous around these parts
Any expectations set on HP/TQ gains? I assume that an engine drop is required to install the intake?
I am considering this mod, and I do not want to throw away my EVO Stage 4 ECU upgrade. Can this be upgraded to incorporate the intake?
Old Feb 14, 2004 | 05:56 PM
PorschePhd's Avatar
The data logs I took last night and this afternoon are supporting the change is with in the swing of the adaptive control in the program. The system is spooling faster and my AFRs are still hitting target.
Old Feb 14, 2004 | 07:29 PM
cjv's Avatar
cjv
Moderator
I guess we did something right when we developed that intake for my car.
Old Feb 14, 2004 | 08:02 PM
PorschePhd's Avatar
The thing is still a pain in the **** to install!!
Old Feb 14, 2004 | 08:37 PM
cjv's Avatar
cjv
Moderator
Stephen,
Others use aluminum which is a big heat sink. Still others use hoses. These have no heat sink, they are light, they have a larger diameter and they flow better.
Yep, they are a tight fit and a pain in the butt for rookies to install.
Old Feb 14, 2004 | 08:39 PM
cjv's Avatar
cjv
Moderator
Sorry, I couldn't resist. Just kidding.
Old Feb 14, 2004 | 08:59 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Originally posted by cjv
Stephen,
Chad, I am a rookie, why don't you come out to Chicago and install one, I mean show me how to install one.
Old Feb 14, 2004 | 09:06 PM
PorschePhd's Avatar
Thanks Chad!....Actually someone gave me the wrong orientation of the pipe. Made for a rather long day Glad that was the case as I was certain I needed a new profession!
Old Feb 14, 2004 | 09:08 PM
sharkster's Avatar
Rookie my ****! I just need to be able to take a picture of you working with your arms/hands still...
