Front plate install (no visible holes)
Old Feb 15, 2004 | 04:16 PM
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
I decided to install my front plate, there are only two holes at the very bottom.
1) I backed the plate with several coats of duct tape.
2) Bent plate to fit the contour of the bumper.
3) Drilled two small holes at the inside bottom of the bumper.
4) Screwed in plate.
I drive at night and often bump into police road blocks, so having a front plate is a good idea, I can easily remove it with no visible damage to bumper with this method.
Old Feb 15, 2004 | 04:38 PM
DaveH's Avatar
DaveH is a jewel in the roughDaveH is a jewel in the roughDaveH is a jewel in the rough
If I understand right, your plate isn't secured at the top in any way. Doesn't it still have the potential to move around, especially on rough road surfaces?
Thank Christ I don't have to dick around with front plate laws here in Indian-no-place.
Old Feb 15, 2004 | 04:41 PM
Rave TT's Avatar
Happy Now?
It is very secure, doesn't move at all.
Old Feb 15, 2004 | 04:42 PM
Turbo Fanatic's Avatar
Probably a good idea
I would recommend paying close attention to make sure that it is not flopping or moving in any way. The scratches from such a movement would cause much more damage than a couple of holes.
Old Feb 15, 2004 | 04:44 PM
Rave TT's Avatar
Happy Now?
Re: Probably a good idea
no flopping at all (it's a metal plate not a peice of paper).
Old Feb 15, 2004 | 06:43 PM
fbrick's Avatar
fbrick is infamous around these parts
And the duct tape would prevent scratching and rattles (not that you might hear them anyway) . . . .
Old Feb 15, 2004 | 07:01 PM
20C4S's Avatar
i think plate looks better when it's FLAT
Old Feb 15, 2004 | 08:03 PM
Rave TT's Avatar
Happy Now?
Huh? It is flat and right up against the bumper.
Old Feb 15, 2004 | 08:34 PM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
I am confused.
The car comes with a plate bracket that secures through two holes that are already IN your bumper. You drilled two additional holes and mangled the plate to bend over / around the bumper?
I am sorry, but I don't get it.
Old Feb 15, 2004 | 08:37 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Originally posted by dpblessing
I am confused.
I was thinking the same thing. I am not sure I understand, either.
Rave TT's Avatar
Happy Now?
I am confused.
My bumper didn't come with the bracket and has no holes in the front of the bumper.
Old Feb 15, 2004 | 08:40 PM
Periokid's Avatar
Well then I can understand. Is that a stock bumper?
Old Feb 15, 2004 | 08:44 PM
Rave TT's Avatar
Happy Now?
I think it is the euro version (drbill would know).
Old Feb 16, 2004 | 05:30 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
I'll chime in. It is the stock bumper that had the bumperette-removal surgery and the plate-hole fill in at the same time. Dr. Bill had no intention of using his front plate so they filled in the holes for a cleaner look.
Old Feb 16, 2004 | 07:36 AM
drbill's Avatar
drbill is infamous around these parts
thanks for answering for me, Jim. euro bumper- no front plate holes. keep the plate off, you wimp!
