Gt2 suspension
Old Dec 6, 2006 | 07:21 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Gt2 suspension
I have the Öhlins Clubsport setup already but what do i need to add more to get a perfect car..I have seen that GMG have alot of nice parts, do i need all or what do i need
Old Dec 6, 2006 | 09:13 PM
tom kerr's Avatar
your shocks are great, need to make sure the springs, helper springs, camber plates, drop links and sways are all just as good and work well together. Talk to whoever did the Ohlins those are already an awesome set up!!
What sways are on and are they rear or front and rear?
Also, what is your ultimate goal for the car? If it is street use you should already be ok. My comments were more track oriented.
Old Dec 6, 2006 | 09:30 PM
sharkster's Avatar
SMR if not then do the upper arms/links and monoballs everywhere. It'll make noise but hold the alignment better. Plus gives you more options. You can do the lower too but you can just use the GT3/2 lower arms that have the camber adjusted via shims etc...
Old Dec 6, 2006 | 09:50 PM
cgmeredithjr's Avatar
cgmeredithjr is infamous around these parts
Originally Posted by sharkster
SMR do the uprights and go the full 9 yards if you're going to do RWD. If not then do the upper arms/links and monoballs everywhere. It'll make noise but hold the alignment better. Plus gives you more options. You can do the lower too but you can just use the GT3/2 lower arms that have the camber adjusted via shims etc...
Hey Sharky,
I think his car IS a GT2. I would recommend the beautiful GT2 suspension pieces that Fabryce sells from GMG...gets rid of the rubber and really tightens up the car and it will hold an alignment, I was very happy with the set up...till I sold the car to Claus...I miss her so badly!
Cleve
Old Dec 6, 2006 | 10:03 PM
sharkster's Avatar
Originally Posted by cgmeredithjr
Hey Sharky,
Cleve
duh.. sorry just late. duely noted
Old Dec 7, 2006 | 03:36 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
SMR
If you are in so cal and want to see the parts up close please stop by our open house this saturday dec 9-from 12-5
I run this set up on my Gt2 that is street driven.. This is also the car that CRUSHED the competiton in the Eurotuner/Superstreet TimeAttack Finale at Buttonwillow last month...
Or just give me a ring and we can get you set up...
Guys, thanks for the kind words on the parts..
Old Dec 7, 2006 | 09:15 AM
SMR's Avatar
SMR
Hello
No im in winter Sweden so a little hard to come buy...
I have seen al your nce parts but im thinking if i need them all, i have heard that the toe links will just do...I already have adjustable sways and stuff like that as you know
Old Dec 7, 2006 | 11:02 AM
sharkster's Avatar
Originally Posted by Fabryce@GMGRacing
SMR
Wouldn't drive anywhere without them
Old Dec 14, 2006 | 08:47 PM
SMR's Avatar
SMR
I have started to install the suspension now and i go nuts on all the adjustment options the gt2 have, first the topmounts are very nice with a diffrent patterns, then the suspension tower has adjustble holes so the camber can be adjusted, and on top of that the lower suspension arm can be shimsed in and out
Please expalin a little for me
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
