CEL driving me nuts. Please help:
Like mentioned above, it is probably due to the MAF sensor. Ive had mine replaced and no more problems. I also upgraded to the FR6s....definitiely a must if you have an exhaust or any software program on your car.
I had the secondary air injection when I bought my car. I replaced the diverter valves and the poblem was solved. Hope that helps. GL
-Suman
Do diverters and maf and see where your at
-Suman
Originally Posted by rcalcaide
Hi,
My CEL light just came on. I switched to a cargraphic exhaust. I have an 02 X50 with 8k miles.Im sure its the 02 sensor. I will probably have it reset. but if it comes on again, does anyone know of an easy fix?
R
R
How can you be sure it is the O2 sensor?
You can get the exhaust place or the dealer to check the connection, or alternatively you can get them replaced.
Good luck and let us know how you go.
P0410 is secondary air pump not triggering. Do you hear this pump come on when you cold start the engine?
If you don't hear the pump check the wiring connections. You might have pulled something loose doing the exhaust mod.
Check the air pump fuse. I'm not sure which fuse. I think the fuses are listed on a label on the inside of the fuse lid.
If the fuse is ok there's a relay IIRC that can be bad.
If the connections are good and the fuse is good and the relay is good, then suspect the hoses or their connections.
jhsalah
Detailing
Sep 24, 2015 05:40 AM
bmwtmx
Aug 26, 2015 07:26 AM
