ABS and PSM failure now......
Old Jul 11, 2014 | 08:23 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
So like an idiot i sloved my missfire by plugging in coil pack #1 since I forgot earlier. Now I get in the car and get on it a bit and get PSM and ABS lights visit WORK SHOP. I checked the wheel sensors to see if i pulled any loose but all are good. I did pull the drivers side intercooler hoses when i planned on removing the intercoolers, but I put them back along with the clips. The car drives fine until I give it alittle gas and tries to build boost. Any ideas??
Old Jul 11, 2014 | 08:27 PM
IITURBO's Avatar
I forgot to mention that I have the rear bumper and tail lights removed. Would the tail lights off cause this issue?
Old Jul 11, 2014 | 08:29 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
its the intercooler hoses you touched.Pull on them hard i bet one is loose or out.Also check to make sure the rubber o rings on the intercooler hoses you touched are seated properly.
Old Jul 11, 2014 | 08:36 PM
IITURBO's Avatar
Ok thanks, I gotta check them tomorrow. I've been in the garage all day and my wife wants kill me lol.
Old Jul 11, 2014 | 09:10 PM
dwdwdwwd's Avatar
dwdwdwwd is infamous around these parts
Try pluging back tail lights and report back.
Old Jul 11, 2014 | 09:17 PM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
absolutely
Old Jul 11, 2014 | 11:44 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Tail lights are not causing your inability to build boost! Do a proper boost leak test, then report back.
Old Jul 12, 2014 | 03:50 AM
e36uc's Avatar
e36uc has a spectacular aura aboute36uc has a spectacular aura aboute36uc has a spectacular aura about
check your MAF
Old Jul 12, 2014 | 04:30 AM
levinsje's Avatar
levinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to behold
I also think it is a boost hose that came loose as this happened to me and I had the same symptoms as you.
When installing the hoses, you need to hear the retaining clips click twice. Then pull/rock the hose to make sure it is locked in place.
Old Jul 12, 2014 | 05:38 AM
Tim941NYC's Avatar
plus 3 on boost hose
Old Jul 12, 2014 | 07:08 AM
joetwint's Avatar
the tail lights will throw the abs code for sure but if your losing boost thats obviously not it lol
Old Jul 12, 2014 | 07:50 AM
dwdwdwwd's Avatar
I missed the "no boost" part.
Like joetwint said tail lights WILL show PSM/ABS failure.
For the lack of boost try unpluging MAF and see how that works for you. Otherwise check boost hose.
Hope you find the problem!
Old Jul 12, 2014 | 08:02 AM
IITURBO's Avatar
Thanks for the replies guys. I went into the garage before I head out for work this morning and confirmed the lower IC hose had blown off. I'll button it up after work and take it for another spin.
Old Jul 12, 2014 | 04:56 PM
IITURBO's Avatar
Ok so i put the hose back in its place and drove the car around, wow what a difference. It pulls so much harder and idles way smoother than before. Thanks again for the tips guys!!!!
randalldahme
Feb 19, 2016 03:56 PM
DYL 911
Oct 1, 2015 02:47 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
ophtho
Sep 18, 2015 03:00 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
