Europipe installation
Old Feb 17, 2004 | 09:24 AM
klong's Avatar
klong is infamous around these parts
Question Europipe installation
Just ordered a Europipe Stage 2 (loud) to be delivered next Tuesday. I am fairly mechanically inclined and have worked with my hands most of my life. However, I'm 54 and not real sure I want to wrestle with that Exhaust, in my garage, on jacks. Is it a piece of cake to install or should I just say screw it and take it to the dealer. I would appreciate your feedback. Thanks.
Old Feb 17, 2004 | 10:57 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Re: Europipe installation
Here's a link for my Europipe installation gallery for my GT3. Much of the necessary procedure to get the car ready to actually remove the stock stuff applies here, like removing the rear bumper and heat shields. This will at least give you an idea whether you want to tackle this project or not. The turbo exhaust replacement is much simpler than the NA exhaust since the cats and mufflers are combined into one unit...
http://gallery.rennlist.com/gallery/albuq91
Old Feb 17, 2004 | 12:22 PM
MTBR's Avatar
MTBR is infamous around these parts
While the protocol for removing/installing the exhaust may be simple, you must keep in mind that both the stock and the Europipe exhaust units are 50+ pounds.
Are you planning on using a lift or jack stands? Wrestling the exhaust while on your back with the car on jack stands will not be the most pleasant experience.
Will you have a partner to assist you?
Old Feb 17, 2004 | 12:33 PM
klong's Avatar
No, I was planning to do it alone. I wasn't too concerned about exhaust weight ( maybe I should be LOL). I was concerned about the difficulty in disconnecting the O2 and lambda connectors and unclipping the sensor wires. I am getting impatient in my old age and I don't know how long I can lay under the car to screw with it to be honest.
Old Feb 17, 2004 | 12:36 PM
msindi's Avatar
Surely you can bench more than 50 lbs. Dan LOL
(just kidding man...seriously...)
Old Feb 17, 2004 | 02:16 PM
MTBR's Avatar
Make sure you re-attach the O2 sensors in the same order; If you reverse the order, you'll trigger the CE light.
Old Feb 17, 2004 | 02:23 PM
rockitman's Avatar
The wires for the sensors for each side should have different colors. The pre-cat Lambda sensor should be blue or green or something like that. The post-cat O2 sensor should have black wiring. That's how it was on my GT3
Old Feb 17, 2004 | 02:38 PM
klong's Avatar
Do you mean that whatever order that I disassemble the sensors that they have to go back togrther in the exact reverse order? Also, I have never actually traced the sensor wires into the engine compartment. Can I easily access this end or is it easier to just remove sensors below and then let them dangle while I install new system?
Old Feb 17, 2004 | 07:35 PM
klong's Avatar
Thank you .You have been most helpful. Everyone on this board is terrific.
Old Feb 17, 2004 | 11:44 PM
rspiteri's Avatar
rspiteri is infamous around these parts
I installed my Europipe II loud about 6 months ago. I love it in the morning on those cold starts. It is music to my ears. After it settles down the sound is sweet and provides just the right tone to keep the true Porsche sound with just a little growl.
My PSS-9 is my favorite mod because it simply takes the car to another level. But a not too distant second is the Europipe.
Stage 2 is great but how fast can you really go. Too many loons on the road here in N. Cal.
Enjoy you Europipe... you made a wise choice.
audipwr1
Sep 25, 2021 01:31 PM
MadWhip
Sep 3, 2015 02:04 PM
