Attn: 6speeders..any words of wisdom for me? changing my dv 's
Old Feb 19, 2004 | 04:00 PM
sporters78's Avatar
sporters78 is infamous around these parts
ok , i'm changing my dv valves this weekend any words of wisdom to help me do this?
Old Feb 19, 2004 | 04:26 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Are your DV's "honking" or otherwise making noise?
Old Feb 19, 2004 | 04:32 PM
sporters78's Avatar
Dock,
they may be making some noise but i have got this pretty Evo billet valves sitting here just waiting to be put in. i can't seem to help myself, i must mod!!!
Old Feb 19, 2004 | 04:48 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
give yourself a decent amount of time...and I hope you have very small hands! It's a major PITA!!!!
Old Feb 19, 2004 | 04:51 PM
My DV's were making noise and the dealer replaced them with Bailey's...under warranty.
Nothing wrong with paying for DV's and replacing them yourself though...
Old Feb 19, 2004 | 05:55 PM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
Good luck and go slowly. Replace all the POS tension-closing clamps with a screw type. Be careful not to slip and make a gauge in the soft rubber hose to the left of them, ask me how I know. If you repeat my blunder I actually have a spare one in my garage.
Old Feb 19, 2004 | 06:00 PM
sporters78's Avatar
Ok red devil ,i'm going to ask... how do you know about making a gauge in the rubber hose?
Old Feb 19, 2004 | 09:29 PM
Orli930's Avatar
Orli930 is infamous around these parts
Steve,
Whats the matter..............bored?? You have about 7 or 8 hours with nothing to do???
Old Feb 20, 2004 | 07:11 AM
sporters78's Avatar
ooh man i hope this only takes 2 hour not 7 or 8
Old Feb 20, 2004 | 07:24 AM
PorschePhd's Avatar
If you get stuck here is a write up a did a while back.
http://www.imagineauto.com/tips1.htm
Old Feb 20, 2004 | 07:29 AM
msindi's Avatar
it took me 2 hours and it was my second ever DIY...those clamps are mean *****...I replaced all the factory ones with the screw type...
Good luck!!!
Old Feb 20, 2004 | 08:33 AM
tme's Avatar
tme
tme is infamous around these parts
If you can drop the engine down a few inches it makes it alot easier
Old Feb 20, 2004 | 09:22 AM
The low end of the process is ~50 minutes. That's how long it took my mechanic to change mine, and that included the time it took to take one of the valves apart to rotate the top to a better angle for installation.
Old Feb 20, 2004 | 09:27 AM
msindi's Avatar
mine came with 90 degree valves which were not moveable/adjustable and fit/cleared just fine...
I got the Bailey DV30s from Mike at AWE...
Old Feb 20, 2004 | 07:20 PM
Mine have 90 degree fittings too, it's just which way the 90 degree fitting is pointed that's the issue. The top of the Bailey valve can be removed allowing the top portion (including the attached fitting) to be rotated and aligned differently relative to the other hose fittings on the valve.
