Methanol injection anyone?
Originally Posted by Origyns 973
Eddie ran with alcohol injection with the drag car he previously built that was stolen.
I believe the car put down 1100rwhp when it was first dyno'ed, then it was stolen.
I have meth injection on my caddy CTS-V runs phenominal, I use ALKY CONTROL kit. I prefer the 50-50 mix, it cools the intake charge by
30 percent. this would solve the intercooler problems associated with our
cars. by the way the caddy is FI (magnacharged).
Originally Posted by topgun
Eddie Bello is a Bum & a thief, I no from experience. Dirty like no other!!
PM me in that case to tell me what had happened and I'll have a response from him within 24 hours, no need to put him down.
Originally Posted by VRAlexander
I had methanol injection on most of my cars (turbo and blown)...then I lost two motors because the pump failed....removed all the units...no more MI...
- chuck
Guest
Posts: n/a
Originally Posted by carendt242
there were no fail safes built into the systems you ran?
- chuck
- chuck
Somebody please correct me....
or confirm that I'm correct.
From my indy car racing days at Cosworth in the UK (where I helped design the ECU), I could have sworn that methonal had a lower energy density than pump gas - Am I mistaken here ? Thus effectively adding methonal cools and adds more oxygen to the fuel input rather than raising the octane rating ?
BTW
The lower engergy density (?) caused some interesting problems getting enough of it into the engine when at WOT /13,500 rpm (about 240MPH) and about 1.8mpg - so we had a bank of 6 pre-compression injectors squirting fuel directly into the intake of the turbo charger !
The PCI's added fuel and cooled the air a little at the same time - after a race the engine had to be 'pickled' on regular gas for a while otherwise the methonal would gum up the injectors.
Just thought I'd share a few memories - as for dyno testing and exploding engines in F1, that's a whole new chapter.....
BTW
BTW
BTW
there are several advantages w/ meth-water injection
-consistent in take tempertures 90-95 degree days
-pumps the octane up,run safer boost levels
disadvantages
-meth is very corosive esp for our motors
-if it's used as in additional fuel & the pump fails
-highly flamable most guys use the windsheild washer resoiver which in IMHO
isn't save.
disadvantages
isn't save.
COBB Tuning
Jan 5, 2016 07:06 AM
proTUNING Freaks
Oct 13, 2015 08:12 PM
