View Poll Results: What boost do you achieve w/modified ECO and NO WG mod.?
All I get is .9
7.14%
I hit 1.0
25.00%
I hit 1.1
42.86%
I hit 1.2
25.00%
Voters: 28. You may not vote on this poll
Poll: Boost for X50 w/Modified ECU
Old Dec 22, 2006 | 06:23 PM
wross996TT's Avatar
Wondering for guys who have modified their ECU programming without changing wastegates what boost you are seeing. Some guy on another site claims to have gotten his data from 6speed saying that no X50 cars can get over .9 bars unless they change wastegates.
Old Dec 22, 2006 | 06:49 PM
WOODTSTER's Avatar
calling Dr. Tom (Kerr)??
Old Dec 22, 2006 | 07:08 PM
Kevinw23's Avatar
Kevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the roughKevinw23 is a jewel in the rough
My car is a non x50 car and I get 1.0 bar with no problem at all. Did the GIAC Flash and I didn't upgrade the dv's yet.
Kevin
Old Dec 22, 2006 | 07:39 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
My GT2 consistently got .9, and would occasionally see 1.0 & 1.1 with a REVO SPS3 program that is supposed to yield 1.2.
Then I upgraded the wastegates and now I get 1.1 - 1.2 consistently. I've even seen 1.3 once or twice.
Aside from the max boost increase, I also get more boost much earlier than I ever did before which makes WAY MORE torque.
If you're considering changing the wastegates... just do it!
Old Dec 22, 2006 | 07:43 PM
wross996TT's Avatar
Yes I know about the wastegates. I have them ready to install. This is about a fellow P-car owner who has indicated that an X50 car can not get over .9 bar with just a flash. I beg to differ. That is all.
Old Dec 22, 2006 | 07:57 PM
ExTex50's Avatar
ExTex50 is infamous around these parts
I have an X50 and haven't changed the wastegates. I regularly see 1.1 bar after the GIAC flash.
Mark
Old Dec 22, 2006 | 07:58 PM
Kevinw23's Avatar
I am going to ask a dumb question...so forgive me. Are wastegates and diverter valves the same thing????
Kevin
Old Dec 22, 2006 | 09:30 PM
Turbo Fanatic's Avatar
The GIAC flash calls to tighten the stock wastegates on X50 cars. No matter who you get your flash from, the factory wastegate springs are weak and can not keep the exhaust pressure from forcing open the wastegates. This will result in low and uneven boost control.
Keep in mind that .9 BAR means .9 BAR power. Your friend is not getting any sizeable power increase from his flash.
IMO the wastegate mod (or EVO replacement wastegates) are mandatory on cars running over 1 BAR boost.
I felt a tremendous increase in midrange torque after the wastegate mod performed at the Speed Gallery. The car has much more midrange punch and stronger top end. I wasn't happy with my flash until Speed Gallery came to the rescue.
Old Dec 22, 2006 | 09:35 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
my stock '03X50 would easily get .9 then I did flash and would see 1.1 easily, then i did wastegate and now frequently see 1.3 spikes, holds 1.2 all day long!
Old Dec 22, 2006 | 10:26 PM
Same here. Feels much better after the wastegate mod.
Old Dec 22, 2006 | 10:29 PM
there is a difference between hitting a boost level and sustaining it... spikes should not count... ur true boost level is 4th gear pull sustained...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 22, 2006 | 11:08 PM
cpu77's Avatar
cpu77 is infamous around these parts
I am stock and get .9
Old Dec 23, 2006 | 12:43 AM
Bodybag's Avatar
Yeah... what he said.
Old Dec 23, 2006 | 08:33 AM
03-turbo911's Avatar
Senior Member
My turbo S was stock and I got a 0.9 as well.
Old Dec 23, 2006 | 09:18 AM
achilles99's Avatar
achilles99 is infamous around these parts
Thanks wross, I'm the one who collected the initial data and no one wants to boost over 1bar more than I!
It sounds like there could be a simple explanation here... if GIAC calls for a tightening of the wastegate, that would explain why I can't get over 1 bar (CONSISTENTLY, not spikes. I can spike to 1.2 periodically, but I can't hold it).
So, it looks like most X50 owners see .9 bar stock, and then 1.1 after a flash and most likely a stock wastegate tightening.
One thing everyone seems to be in agreement on, though. Replacing the stock wastegate springs will allow higher boost alongside programming. I had a 1.4bar program installed, and couldn't get over .9 bar. I have 60k miles on my X50 car, so if anyone has weak springs it would be me!
