Oil Catch Can Installation/Recommendations?
Old Jan 5, 2007 | 11:20 PM
L Gancho's Avatar
L Gancho is infamous around these parts
How does one plumb an oil catch can correctly using the stock pcv system? This is a simple question for an expected complicated answer.
Old Jan 5, 2007 | 11:58 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
i guess the simpler question is why?
- chuck
Old Jan 6, 2007 | 04:36 PM
L Gancho's Avatar
Positive crankcase ventilation. Cranckcase fumes (oil) caused by blowby are circulated back into the combustion chamber via the intake manifold or the intake charge upstream of the compressor/intercooler to be burned again. This is done partly for emmissions. The catch can would condense the oil from the fumes when placed inline with the pcv system, in order to prevent any oil fumes from going back through the intake. Perhaps someone could provide an emmission control diagram? I would like to learn more about the pcv system.
Old Jan 6, 2007 | 06:20 PM
carendt242's Avatar
i guess my question was why do you think you need it on the porsche? how much boost do you intend to run?
- chuck
Old Jan 6, 2007 | 06:45 PM
Redridge's Avatar
- chuck
It really wouldnt hurt and would probably be a good idea. I read a post here about oil being past the fill mark and then made its way to the intake to get burned (not good). But if the catch was there, no worries. It just remove extra oil so that your intake is cleaner that all. The problem is where do you put it?
ECS Tuning - VW
Sep 8, 2015 01:34 PM
TurboDragon
Sep 4, 2015 09:11 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
