What is typical HP +Tq for stg 3 and 4?
Old Jan 12, 2007 | 10:25 AM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
I know this topic has been discussed before but Im still not really clear. I am looking for an affordable way to increase power. Ive seen alot of different power claims out of k24's and Im not really sure what most people are seeing. How much could I expect to gain with k24's compared to my stage 2? Also are k24 headers proven to make substantial increases in HP and Tq?
Old Jan 12, 2007 | 10:47 AM
buddyg's Avatar
From Evoms.com
Price: $12,500.00 USD
·Stage 3·
SKU:TUN996TTL3
The Stage 3 system expands upon the Stage 2 system by adding GT1 K24 Sport Turbos. The biggest difference between the KKK16 and the K24 Turbos is the size of the impellers and the amount of air that each Turbo can safely generate. The KKK16’s can safely deliver up to 1.1 BAR of boost and about 525 HP, while the K24’s can safely deliver up to 1.3 BAR of boost and 625 HP. Upgrading to the K24 Turbos is simply like upgrading from a basic Twin-Turbo up to an X50 / GT / S. This is a very safe and easy installation upgrade because the X50 / GT2 / S Twin-Turbos come with the K24’s from the factory. By adding the K24’s there is no increase in turbo lag due to our specially designed computer program that increases the bottom end power as well as compensates for the increased airflow of these larger turbos.
Price: $14,300.00 USD
·Stage 4·
SKU:TUN996TTL4
The Stage 4 system expands upon the Stage 3 system by adding high flow headers. Once a car is equipped with the K24 Turbos, the stock header system poses the same problem that was addressed in stage 2. The OEM header is restricted due to the flat collector design and poor flow characteristics. To remedy this problem, we offer a high quality, stainless steel, equal length header system with a hand fabricated pyramid merge collector. This collector and header design increases exhaust velocity to the turbos for better spool up as well as overall performance.
Old Jan 12, 2007 | 10:54 AM
rwm514's Avatar
Thx buddy,
Is there anyone who can give a first hand impression of going from stage 2 to 3 or 4, maybe some comparison dyno numbers?
Are peolple really seeing 100hp increases like evoms states?
Old Jan 12, 2007 | 10:59 AM
there are so many different variables when it comes to this that there is not one way to describe it...
I can show you two P cars both with 600 crank HP but with different tuning approaches.... guess what... they will not run equal even though they produced the same HP on the dyno...
Don't get hung up on numbers as much as get in a car with a kit b4 you buy...
I wish I did....
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 12, 2007 | 04:43 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Rob,
From my experience, the jump from K16 stage 2 to K16/24 stage 3-4 is significant. The car is much faster. I would say it is like the difference of going from stock to stage 2 once again, perhaps a little more. The power comes on much harder.
Old Jan 12, 2007 | 05:14 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
If you're talking about stock k16's with GIAC stage II, and stock k24's with GIAC stage IV, you're realistically at around a 50hp difference to the wheels.
Your stage II will put "around" 450hp to the wheels, and a stage IV will put "around" 500hp to the wheels. Of course there are a million variables, but that is about what you'll see.
You really have to drive both, and decide what you like better. If it were me, and I were running a stage II car, I would not spend the money on stock 24's. Thats a lot of money, for not a whole lot of difference.
Once you get away from the stock 24's, you have about a hundred different choices/packages.
Old Jan 12, 2007 | 05:25 PM
rwm514's Avatar
Originally Posted by John D II
Rob,
So you are referring to hybrids right? I was actually wondering about regular old k24's as some used ones are coming on the market pretty cheaply now.
Old Jan 12, 2007 | 05:27 PM
rwm514's Avatar
Thats what I was wondering, 50 hp probably isnt worth the money and slight increase in lag to bother with. 100 hp though, hmmm... might be worth it.
Old Jan 12, 2007 | 05:37 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
I'm not sure how much this compares in an apples-to-apples test, but I made the switch from K16's to K24's on my 993TT after everyone said it was the "way to go", and I was completely dissappointed.
Maybe, and just maybe, there was a little more power way up in the RPM range, but it was almost impossible to even register a difference in "seat-of-the-pants" testing. Not worth the money I spent, that's for sure.
It might be way different on a 996 because of the 4 valves per head thing, and the ability to breathe more air, but I would get a ride or two first and do your own comparo before you spend your hard earned greenbacks.
$.02
Old Jan 12, 2007 | 05:44 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
My K24 / 18g hybrids are putting down almost 500 AWHP! Trust me - the car is FAST!
Old Jan 12, 2007 | 07:23 PM
John D's Avatar
Rob,
Yes, the hybrids. I think that they are a great way to go - especially for the money relative to other packages.
Old Jan 12, 2007 | 09:06 PM
WOODTSTER's Avatar
BodyBag: good advice
If you switch out turbos do not settle on old stock K-24 technology
not enough bang for your buck.
MK
Old Jan 12, 2007 | 09:09 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Put rods and heads in the car...just get it over with..like me, Kevin
Old Jan 12, 2007 | 09:22 PM
WOODTSTER's Avatar
In Major home remodeling business we call that the:
"might as well" clause. As long as we already tearing out the old...
LOL, get it over with!
Old Jan 12, 2007 | 09:30 PM
KPG's Avatar
KPG
And in your informed opinion...is it cheaper in the end? Keep in mind in a 12 month span I will have 3 sets of turbos on the car.
